Old 02-18-2007, 11:02 AM   #1036
Crim3Wav3's Avatar
you'd also need to demel the arewa around the lower shock collars in the arm....with more droop, the retainers will bind on the arm if not dremeled...or you could just buy the new arms.
Crim3Wav3 is offline   Reply With Quote
Old 02-18-2007, 12:32 PM   #1037
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
Yeah...LOL...that too...
But they're the same length and everything else. Unless you looked very closely, you can't tell them apart. About the only part that's visibly different are the upper front arms. The rest of the changes are pretty subtle.
Turbo Joe is offline   Reply With Quote
Old 02-18-2007, 01:21 PM   #1038
madjack's Avatar
Trader Rating: 20 (100%+)
Send a message via Yahoo to madjack
all good info. guys thanks.
I have the Fioroni lower chassis that included some areas that were relieved to increase down travel. I'll check and bust out the dremel if needed.
For those who own the Prospec and 5R (you out there Tony?) Is the measured distance the same? (lower inner hinge pin to shock mount hole)
Thanks again gang!
madjack is offline   Reply With Quote
Old 02-19-2007, 05:16 AM   #1039
TonysScrews's Avatar
To convert you'll need the Front & Rear shocks and shock towers.
You will also need the new upper front arms so the nut on the ackerman does not hit it at full droop. Like said above, you may need to dremel the lower arms where the shock relief is. The MBX5R chassis is also notched where the arms come down and hit the chassis so you may need to dremel there. As for the rest of the car, the new R has an updated servo-saver, ackerman and 4mm steering turnbuckles/ends with larger ball studs. It also has a new -1 lower front plate. I highly recommend the R linkage kit too (unless you use a non-Mugen linkage kit already).
If you or anyone else needs the new MBX5R servo-saver, I have one that I was going to put on my old ProSpec, but sold the car. I'll let it go cheap just email me at tony@tony1034.com. I also have the new larger 7mm ball studs and 4mm steering link ends I'd sell too. The only thing you'd need is the 4mm turnbuckles (can use Mugen or Lunsford).
Best regards,
Tony P.
Tonys Screws LLC
http://www.tonysscrews.com
High Grade Alloy Steel Screws, Screw Kits and Mugen Parts
TonysScrews is offline   Reply With Quote
Old 02-19-2007, 06:42 AM   #1040
Merciless's Avatar
Send a message via ICQ to Merciless
Anyone have an editable .pdf set-up sheet for the 5R ???
I'm having some problems with the rear kicking up in the rougher sections and wanted to post my set-up to see if any of you wizards can help at all ??
Cheers
Rod
Merciless is offline   Reply With Quote
Old 02-19-2007, 07:36 AM   #1041
madjack's Avatar
Best regards,
Thanks Tony, sent you an email.
John
Old 02-19-2007, 10:35 AM   #1042
Crim3Wav3's Avatar
the only thing im missing from my conversion from old prospec to 5R is the front -1 hingepin holder....anybody got one?
Old 02-19-2007, 10:38 AM   #1043
RYAN BARNES's Avatar
Yeah, PM me your mailing address, I'm almost certain I have some extras at home, I'll check tonight after work and if so I can drop it in the mail tomorrow.
RYAN BARNES is offline   Reply With Quote
Old 02-19-2007, 12:31 PM   #1044
dirtracer1's Avatar
please forgive if this has already been covered in here somewhere already, but, without having to go back and read through over a thousand posts, can someone please tell me what the differences are between the mbx5 and the mbx5r are...other than price? a-main hobbies has the mbx5 listed for 369.99 and the mbx5r for 589.99. thanks.
Losi 22
Losi 810-e
Losi SCTE
Losi XXX-MF2/CRC SC
B&T R/C - http://b-treman-rc.valp.net/btrchome.htm
dirtracer1 is offline   Reply With Quote
Old 02-19-2007, 01:37 PM   #1045
t4usee's Avatar
get back to work barnes
t4usee is offline   Reply With Quote
Old 02-19-2007, 01:43 PM   #1046
Turbo Joe's Avatar
Carolina's RC has a very comprehensive list on their website that has all the part numbers that are different...
Old 02-19-2007, 03:12 PM   #1047
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Anyone know the part numbers for the chassis braces from the regular MBx5? I'm running the 5R and I want to try those to get a little more flex in the car over the aluminum ones.
Jon Kerr is offline   Reply With Quote
Old 02-19-2007, 04:40 PM   #1048
n.e.r.d's Avatar
not sure if this has been posted b4,
but i'm just curious...
what's the main reason behind the change in the servo saver?
inverted(5R) vs upright(std 5)?
is it for easier access to the knurled knob?
(tt's what i've been told cos the pros like adjust the spring tension every now and then to suit track conditions.)
does the inverted servo saver really gives more steering compared to the old prospec?
2nd,
what the reason in the change btw the old prospec and newer 5R ackerman steering plate?
the new 5T is still using the old ackerman plate.
(but i'll be using the eck-tec ackerman plate anyway...)
n.e.r.d is offline   Reply With Quote
Old 02-19-2007, 05:22 PM   #1049
Davidka's Avatar
Trader Rating: 75 (100%+)
The reason for flipping over the servo saver is so that when it activates, it won't alter the steering geometry. The ackerman plate just has more adjustability.
Old 02-20-2007, 04:11 PM   #1050
SKOT's Avatar
Do you have a link? Is it in the store or the community? I'm looking to get a Mugen buggy and I'm also wondering about the exact differences between the MBX5, the Prospec and the R.
Some people say the only Prospec upgrades you really need are the front tower, chassis braces and one-piece engine mount. Any truth to that?
SKOT is offline   Reply With Quote
FS Mugen MBX5-T Prospec & MBX5-R Both less than 3 gallons! V-Spec Less than 1 gallon! ffpm46 R/C Items: For Sale/Trade 20 08-01-2008 06:27 PM
whats the difference mbx5 prospec / mbx5 r lynell90 Nitro Off-Road 6 04-24-2008 02:31 PM
Mugen MBX5 Electric Conversion, MBX5 and MBX5R Spare Parts! Cain R/C Items: For Sale/Trade 18 04-10-2008 03:16 PM
Mugen MBX5, MBX5 Pro Spec, MBX5R Differences Cain Nitro Off-Road 12 10-01-2007 10:35 AM
MBX5 or MBX5 PROSPEC? Realworld differences? Jeel Electric Off-Road 5 12-05-2004 07:46 AM
