Old 01-10-2007, 04:36 PM   #856
kaotickc's Avatar
Trader Rating: 43 (100%+)
Thanks guys.....now would I want to run my rear hub carriers in the short or long wheelbase setting ?
kaotickc is offline   Reply With Quote
Old 01-10-2007, 05:26 PM   #857
Send a message via MSN to ickvanovs
Originally Posted by RYAN BARNES
ick- The MBX5 Prospec kits are still a very competitive and durable kit, and the cost to convert them to a R really doesn't add up. You'd be better off to sell one of your MBX5's and order a new R kit, for what it would cost you to convert it. As for the MBX5, just watch the normal wear and tear parts, the plastic bushings front and rear, toe blocks, and arms. Good luck!
hey, thanks for the info.
i just got my kit, seems to be good.
checked everything, i think i need to replace front lower arms and wing.
well, im not intended to upgrade to R. only wondering which parts from the R that might help.
this kit is my first buggy, any recommendation on starting setup?
is it true that in buggy people will mostly change diff oil to get the right setup?
thank you
ickvanovs is offline   Reply With Quote
Old 01-10-2007, 06:29 PM   #858
Originally Posted by kaotickc
Hey, been kinda watchin over this thread and soakin up as much info as possible, esp. from Ryan Barnes . But still have not been able to cure my mid-exit corner push. Any ideas.
Im running a
2.3mm bar
1 small spacer in front of the upper arm
ackerman-middle
shocks- lower/outside hole upper 2nd out from inside
rear
3* toe block
shocks lower/outside hole upper 3rd out from inside
2.8 mm bar
Tracks I run at are small-med and normally hardpack and/or bluegroove. I just cant seem to get the car to stop pushing when on the gas out of a corner! Im fairly new to all this so bare with me if you can guys!
"D"
1. Run the 2.5 toe in block in the rear.
2. And raise your ride height in the rear by 2mm (with the spacers)
3. Less droop in the Front. (don't let front arms droop that much)
Try this and I bet it will work.....
SebsCustom is offline   Reply With Quote
Old 01-10-2007, 06:38 PM   #859
here is a clip of my buggy turning ... I like it to recover quick from a turn so I can give it... and my buggy does that now: Buggy MBX5
Old 01-10-2007, 08:48 PM   #860
gasman517's Avatar
My kids going to try one of ryans setups this weekend, it going to be cold -7c ,will that kind of temp effect the oils in the buggy
gasman517 is offline   Reply With Quote
Old 01-10-2007, 09:13 PM   #861
SpeedBump57's Avatar
Hum............I don't think I would change a thing on that buggy! Just clean it up and put it back on the trailer.........
Nice video by the way.
SpeedBump57 is offline   Reply With Quote
Old 01-10-2007, 09:36 PM   #862
Crim3Wav3's Avatar
Seb,
I am impressed....only one "bobble"....and that was a lapper!
please post your setup...
Crim3Wav3 is offline   Reply With Quote
Old 01-10-2007, 09:45 PM   #863
gasman517's Avatar
I do some pit work for seb and the guy drives like a mad man
Old 01-11-2007, 07:16 AM   #864
kaotickc's Avatar
Ya...nice driving there Seb !
Old 01-11-2007, 11:58 AM   #865
My Setup for the MBX5
Asume everything is stock setup but with the falowing changes:
Rear shock oil 60wt
Front shock oil 50wt
Shocks are attached on the inside hole of the arm (both front and rear), this gives you a lot of droop.
The important part is to adjust your front droop to be less than the rear droop..... if you still push coming out of the corner make the front droop less.
Top of shocks are second last hole from all the way in.
8mm clip ride height adjuster in the rear
2mm clip ride height adjuster in the front
2.5 toe in in the rear
caster (upper arms in the front) all the way back.
Diffs: 5000 - 7000 - 2000
Ackerman... closest hole to steer. post. (agresive)
That's it.
Old 01-11-2007, 12:00 PM   #866
for got this:
2 degree camber in the rear
1 degree in the front
and
upper rear tie rods are attached on the bottom hole on the rear shock tower.
Old 01-12-2007, 07:06 AM   #867
kaotickc's Avatar
Do any of you guys know if these Kyosho bushings will fit in the mugen hinge pin slots ?
http://www.amainhobbies.com/product_...oducts_id/3941
Old 01-12-2007, 07:16 AM   #868
RYAN BARNES's Avatar
Why run K stuff? Get these and never have to buy bushings again!! I've run them for over a year in all my Mugens and their great!!
http://carolinasrc.com/Webstore/Scri...?idproduct=690
RYAN BARNES is offline   Reply With Quote
Old 01-12-2007, 07:20 AM   #869
If you don't wanna spend the extra money for the brass ones, here's a link to the stock Mugen bushings.
http://carolinasrc.com/Webstore/Scri...?idproduct=134
Old 01-12-2007, 08:10 AM   #870
kaotickc's Avatar
Cuz the shop has K ones up there right now. Everytime he stocks the mugens, someone buys the whole rack at a time. Ya, I might look into those one you linked too!
FS Mugen MBX5-T Prospec & MBX5-R Both less than 3 gallons! V-Spec Less than 1 gallon! ffpm46 R/C Items: For Sale/Trade 20 08-01-2008 06:27 PM
whats the difference mbx5 prospec / mbx5 r lynell90 Nitro Off-Road 6 04-24-2008 02:31 PM
Mugen MBX5 Electric Conversion, MBX5 and MBX5R Spare Parts! Cain R/C Items: For Sale/Trade 18 04-10-2008 03:16 PM
Mugen MBX5, MBX5 Pro Spec, MBX5R Differences Cain Nitro Off-Road 12 10-01-2007 10:35 AM
MBX5 or MBX5 PROSPEC? Realworld differences? Jeel Electric Off-Road 5 12-05-2004 07:46 AM
