Old 01-02-2007, 08:00 PM   #781
ira
ira's Avatar
Trader Rating: 18 (100%+)
Originally Posted by rcmike
Where can you get them? Nitrohouse told me today 2 to 3 weeks maybe.He did not have a estimate due date. thanks
What are you looking for??
RC AMERICA, XRAY, FUTABA, O.S. ENGINES, BYRON FUELS, SPEEDWORLD RACEWAY, HOBBICO, MATRIX TIRES...
ira is offline   Reply With Quote
Old 01-02-2007, 08:57 PM   #782
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
The subject line of his post said something about the new springs...
Turbo Joe is offline   Reply With Quote
Old 01-03-2007, 03:15 AM   #783
rcmike's Avatar
Trader Rating: 40 (100%+)
Default mbx5r,mbx5t new shock springs
Hi, Im looking for the new shock springs that fit the mbx5r and mbx5t shocks that mugen recently came out with.Where can i place an order at to get them? Thanks
rcmike is offline   Reply With Quote
Old 01-03-2007, 03:37 AM   #784
Nitro$junkie's Avatar
Send a message via MSN to Nitro$junkie
try http://www.pro-s-futaba.co.jp/ ther web states they got them on the 9th December i emailed them today but still waiting for a reply
Futaba
Mugen
Novarossi
Byron's
http://www.hospitalrecords.com
Nitro$junkie is offline   Reply With Quote
Old 01-03-2007, 05:35 AM   #785
ira
ira's Avatar
You can call or e-mail Mugen USA, they have them in stock.
I should get mine today.
Old 01-03-2007, 05:41 AM   #786
RYAN BARNES's Avatar
Or you can call Mugen USA!!!
RYAN BARNES is offline   Reply With Quote
Old 01-03-2007, 07:39 PM   #787
ira
ira's Avatar
Thanks for the look, it's fixed.
Old 01-03-2007, 08:30 PM   #788
teeforb's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to teeforb
Have anyone notice any major difference in performance between the mbx5 and mbx5r? From one of these posts, someone mentioned that the parts between the mbx5 and mbx5r are almost identical.
$$ Team High Budget $$
17.5 stock buggy fb page
https://www.facebook.com/groups/17.5stockbuggy/
teeforb is offline   Reply With Quote
Old 01-03-2007, 08:38 PM   #789
No not "identical", they were just saying that you can put all of the MBX5R upgrades on the MBX5 chassis. But if you don't currently own a Mugen your better off to go on and get the new R kit, because the suspension and handling is so much better. And for what it cost to fully upgrade the old kit you will honestly save money in the long run by going on and getting a MBX5R. Good Luck!
Old 01-03-2007, 08:43 PM   #790
teeforb's Avatar
I have the mbx5 and i wanted to know if the -R is worth the upgrade. Also, if I upgrade, would it be identical to the -R?
Actually, what would be the minimum parts list to get my mbx5 to handle like the mbx5r?
Also, from doing a little more research on the 5R, I am seeing the main reason for the suspension upgrade is for the extra droop. Can someone explain droop in details and how it affects the car. Also, is droop the same as rebound stop?
Old 01-03-2007, 10:01 PM   #791
Minimum parts- Would have to be Front and Rear shock towers, F & R shocks, Front Upper and Lower arms, and Rear lower arms. That's about as close to an R as you will get the MBX5 for minimal $$$ To give you an idea of how far you still are from the R, here is a link to the complete upgrade comparison list!!
http://carolinasrc.com/Webstore/Scri...idCategory=466
Old 01-03-2007, 10:25 PM   #792
Turbo Joe's Avatar
The servo saver is also well worth the $6...just shorten the stock tube with a file...takes 5 minutes and it has less slop than an "R".
I haven't measured it out, but I had to limit my EPA more after I installed it. It had quite a bit more steering throw from just that one part.
Old 01-03-2007, 10:27 PM   #793
Rebound stop and droop are somewhat the same, or atleast they work torward the same principal. "Full Droop" would be when the arms and shocks are at full extension, as when the buggy is in the air, the new R has alot more droop(suspension travel) than the previous MBX5. Now you can limit your rebound or droop using the "droop screws" which are set screws located in all 4 lower arms. As I have stated on previous pages I choose not to use the droop screws as they dig into the aluminum chassis and get out of adjustment. I remove the set screws completly from my lower arms and set droop using a black rubber o-ring internally in my shock body. I simply place the o-ring on the shock shaft under the piston before I place it in the shock body.
Old 01-03-2007, 10:45 PM   #794
Turbo Joe's Avatar
Like I said before, I had to limit mine to get to the 10mm figure on the "R" setup sheet with a stock prospec chassis...I can't see where the newer chassis would make any difference at all.
Definitely going to do the o-ring deal next time I do the shocks though. That's how we roll in the Tamiya Minis.
Old 01-03-2007, 11:30 PM   #795
got my price back from http://www.pro-s-futaba.co.jp/ cant beleve how cheap they were
1x E0528 Front Spring (Long 14.5T) Light Blue 720yen = $6
1x E0529 Front Spring (Long 14T) Gray 720yen = $6
1x E0530 Front Spring (Long 13.5T) White 720yen = $6
1x E0531 Rear Spring (Long 17.5T) Light Blue 760yen = $6.30
1x E0532 Rear Spring (Long 17T) Gray 760yen = $6.30
1x E0533 Rear Spring (Long 16.5T) White 760yen =$6.30
1x E0317 Servo Saver Pipe (Teflon Coating 520yen = $4.30
1x E0704 Al. Clutch Shoe (Light Weight) 1120yen = $9.30
1x B0103 Mugen fuel filter 680yen = $5.60
1x B0115 Mugen Fuel bottle 800yen = $6.70 all converted to US dollar
Futaba
Mugen
Novarossi
Byron's
FS Mugen MBX5-T Prospec & MBX5-R Both less than 3 gallons! V-Spec Less than 1 gallon! ffpm46 R/C Items: For Sale/Trade 20 08-01-2008 06:27 PM
whats the difference mbx5 prospec / mbx5 r lynell90 Nitro Off-Road 6 04-24-2008 02:31 PM
Mugen MBX5 Electric Conversion, MBX5 and MBX5R Spare Parts! Cain R/C Items: For Sale/Trade 18 04-10-2008 03:16 PM
Mugen MBX5, MBX5 Pro Spec, MBX5R Differences Cain Nitro Off-Road 12 10-01-2007 10:35 AM
MBX5 or MBX5 PROSPEC? Realworld differences? Jeel Electric Off-Road 5 12-05-2004 07:46 AM
