Old 10-28-2006, 12:56 AM   #511
keyesgood's Avatar
Default set up help
mr barnes
you da man ,
thanks heaps as im building it right now , first gas buggy allways run electric offroad before .
mike , perth oz'e
p.s the manuals not very good needed to look at pic's on the mugen site , as iv never built a mugen kit before ,
MBX7, O.S SPEED , SANWA , STOCK CLUB CAR
MBX7 O.S SPEED , SANWA , FULLY BOMDED KEYSEY TURBO EDITION
keyesgood is offline   Reply With Quote
Old 10-28-2006, 03:56 AM   #512
keyesgood's Avatar
Default mr barnes ,
hello again ,
pal ,
iv had an pm from one of the top factory mugen drivers here in australia , the gray springs are not new longer ones , they just pul them hard and make them longer , do this a few times and then check them to see if they are the same , iv done it looks fine to me , then they only run a little clip in the top of the shock , as you pointed out mr scott hughes had done ,
keep it under the sheats ,
mike ,
Old 10-28-2006, 09:20 AM   #513
cornerspeed's Avatar
Is the ackerman plate on the MBX-5R still not a good ackerman to run? Just wondering if I need to raise this one up or get an Eck-Tec plate. Is there a difference?
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 10-28-2006, 10:35 AM   #514
tony montana's Avatar
Trader Rating: 65 (100%+)
what kind of lap time differences are you guys experencing to thr mbx5r compared to the mbx5 prosepc
K.C. Guy. Team Xray - rc america
tony montana is offline   Reply With Quote
Old 10-29-2006, 01:05 AM   #515
I would think that stretching out the springs would distort them and alter the spring rate.
symbology is offline   Reply With Quote
Old 10-29-2006, 04:32 AM   #516
ahsikes's Avatar
Trader Rating: 17 (100%+)
There is always the truggy springs?
ahsikes is offline   Reply With Quote
Old 10-29-2006, 07:31 AM   #517
Ryu Goh's Avatar
Stretching the spring is a idea from KenjiOsaka. The whole idea behind it was to make the spring more progressive.
Ryu Goh is offline   Reply With Quote
Old 10-30-2006, 06:59 PM   #518
RYAN BARNES's Avatar
Here's a good look at the MBX5T wing mount kit mounted on my buggy that I mentioned on page 17. It bolts right on the buggy and the wing holes are the same width. As you can see from my MBX5R, compared to my sons in the background, it makes the wing lower and a little further back which helps with rear traction, and it lowers the buggys center of gravity, which is a big help in cornering!!
Also here is a look at the Eck-Tec ackerman arm next to the King Headz, they both have the 3mm offset which really helps bumpsteer, but the Eck-Tec has 4 holes and offers a lil more tuning options, I'm running it in the 3rd hole from the front, and the steeering is great!
RYAN BARNES is offline   Reply With Quote
Old 10-30-2006, 08:08 PM   #519
So on the ackerman plate. Is it the thickness of the plate, i.e. the hieght of the inner ball stud for the steering link or is the position of the ball stud on the rack, for and aft? I remember about 3 years ago when I last ran 1/8th buggy with my MBX-5 then, that we had to space up the rack for correct bump steer. Is the MBX-5R rack good enough for this?
Thanks for pics and help.
Donny Vinkemulder
TLR Driver
Old 10-30-2006, 08:32 PM   #520
I'll post a pic of the MBX5R ackerman arm next to the King Headz/Eck-Tec arms, at a flat angle tomorrow night so you can better understand. The R arm is still not offset as need to reduce bumpsteer, so you would still have to space it, but with the King Headz or Eck-Tec arms, they come offset so you just bolt them on.
Old 10-30-2006, 10:15 PM   #521
pearldiver's Avatar
Send a message via Yahoo to pearldiver
Ryan..thanks for the pics..
just wondering if the truck wing stands can fit into stock wing? ur wing looks nice, mind telling me what brand is it? thanks..
pearldiver is offline   Reply With Quote
Old 10-31-2006, 12:43 AM   #522
Yes the kit is made for a stock Mugen wing, that is a Himoto universal fit wing in a couple pics, and a Proline wing in the other pic. I usually run the Proline, but was trying the Himoto out that day. It seems to be a really good wing.
Old 10-31-2006, 12:48 AM   #523
keyesgood's Avatar
Default mr barnes
where can i get one of them covers for the airfilter , do you sell them ,
mike keyes , perth australia .
keep up the good work ,
Old 10-31-2006, 03:08 PM   #524
Here are a couple pics to help people better understand the ackerman arms, since you hear of alot of factory drivers putting shims under the ackerman arms or as they say (raising the rack) to reduce bumpsteer. When all you really need is an aftermarket ackerman to solve the problem, such as the one from King Headz.
In the overhead shot the arms appear to be the same.
But when you look at them from level, it's obvious the offset at the end of the King Headz ackerman arm, which raises the steering balls and tie-rod ends, and greatly helps reduce the bumpsteer.
Old 10-31-2006, 03:24 PM   #525
Mike, that prefilter is from OUTERWEARS, and I have a thread on their products here on RCTECH, you can click this link to get to it and it tells you all about them. I think we setup a dealer in Australia, but I'd have to search for the name of that shop. Or you can PM or email me a email address for your local hobby shop and I can have a dealers application sent out. CHEERS!!
http://rctech.net/forum/showthread.php?t=131145
FS Mugen MBX5-T Prospec & MBX5-R Both less than 3 gallons! V-Spec Less than 1 gallon! ffpm46 R/C Items: For Sale/Trade 20 08-01-2008 06:27 PM
whats the difference mbx5 prospec / mbx5 r lynell90 Nitro Off-Road 6 04-24-2008 02:31 PM
Mugen MBX5 Electric Conversion, MBX5 and MBX5R Spare Parts! Cain R/C Items: For Sale/Trade 18 04-10-2008 03:16 PM
Mugen MBX5, MBX5 Pro Spec, MBX5R Differences Cain Nitro Off-Road 12 10-01-2007 10:35 AM
MBX5 or MBX5 PROSPEC? Realworld differences? Jeel Electric Off-Road 5 12-05-2004 07:46 AM
