Old 08-17-2006, 05:49 PM   #406
schmelme's Avatar
Originally Posted by Lextek
Ithink part of my problem is a slightly, worn bushing for the front front brake cam. I was looking at the King Headz center diff plate with the bearings as an upgrade.
It is very easy to replace the bushings with bearings. most hobby shops have 5x8x2.5 bearings (flanged) in stock so all you have to do is drill out the hole in the brake plate to 8mm and put the bearings in and away you go. I have found that using a uni-bit or step bit allows you to make the bearing almost a press fit in the carbon fiber, check fitment often. Its about a 15min job and well worth it. No more brake probs.
schmelme is offline   Reply With Quote
Old 08-17-2006, 06:03 PM   #407
Tony do you have a link/part # for those TTRS3 discs?
Lextek is offline   Reply With Quote
Old 08-17-2006, 06:11 PM   #408
Trader Rating: 24 (100%+)
I've used the Crazy Nut 4 disc brake set up for our Mugens for 3 years now. Carbon fibre pads and hardcoated vented aluminum discs. i had a mchinist buddy, machine the top plates nicely for bearings and I put a drop of ca on the flange to keep the outer flange from rotating, thats when it wears.
MNRC Committee
Josh's "Pit Guy"
Bones Brew Fuel Dealer
Thank you to his sponsors Mugen, J-Concepts, The Nitro Shop, Loosenuts Racing, Savage RC Motorsports, Ford Designs.net and FTR...
Jeff Ford is offline   Reply With Quote
Old 08-17-2006, 06:53 PM   #409
Trader Rating: 22 (100%+)
http://www.amainhobbies.com/product_...oducts_id/2546
I think this is what tony is referring to
sand geek is offline   Reply With Quote
Old 08-18-2006, 06:38 AM   #410
TonysScrews's Avatar
Yep, those are them.
Tony P.
Tonys Screws LLC
http://www.tonysscrews.com
High Grade Alloy Steel Screws, Screw Kits and Mugen Parts
TonysScrews is offline   Reply With Quote
Old 08-18-2006, 08:58 AM   #411
I'm new to 1/8th scale. I think I made the right choice with the Prospec. Seems like there is a great wealth of knowledge here about it.
Old 08-22-2006, 01:51 PM   #412
Merciless's Avatar
Send a message via ICQ to Merciless
Can anyone help out with set-up ??
Track is long grass in a field, Well it's long enough anyway. Providing loads of grip, Traction rolling is a problem if i'm not careful. I'm new to 1/8th and the mugen is my first Nitro buggy.
It seems a really good car Anyway help with diff settings etc would be really appreciated.
I have looked to the mugen site but there didn't seem to be anything there suited to a grassed surface. Oh no jumps but there are some nasty "holes" in the surface, rabbits i guess ...............
Cheers Guys
Merciless is offline   Reply With Quote
Old 08-24-2006, 06:48 PM   #413
Crim3Wav3's Avatar
i dont know about a grass setup but....
Does anybody know whether the new MBX5T front shocks are a direct bolt-on for the MBX5 buggy rear shocks? It sure would be nice to not ruin shock bodies every 5 weeks.....
Crim3Wav3 is offline   Reply With Quote
Old 08-24-2006, 06:51 PM   #414
Crim3Wav3's Avatar
damn i suck...Tony answered that on this page....
Old 08-25-2006, 06:28 PM   #415
I went back and looked at some set-ups. I moved the 2mm spacer for the lower front arm to the front. Big difference. It seems the harder you drive this buggy the better it goes!
Old 09-07-2006, 11:52 PM   #416
Man its been a long time sense i have posted!
I have been lost on the down travel of the setup sheet.
It showes a rim under the chassis and it tells me full. It looks like the rim would stop the full travel of the arms. Is that what they are reaching for? Can someone make it easy on me and let me know the average A arm down stop by ground to chassis or mm's traveled.
P.S. I am looking at the Scott H. and Chad B. setup sheet.
Thanks a bunch
kyracer is offline   Reply With Quote
Old 09-08-2006, 06:59 AM   #417
Davidka's Avatar
Trader Rating: 75 (100%+)
Full down travel means no limiting at all (controlled by the droop screws). The chassis tabs against the bottom of the arms are the limiters. The wheel under the chassis should be ignored.
Old 09-08-2006, 07:20 AM   #418
In measuring the down travel according to a setup sheet you need to use the ride height guage under the hubs-with a wheel under the car chassis. When I go to full down travel I at least run the droop screws in until they contact the chassis and then give them another 1/2 turn or so. That way you don't bend driveshafts or even pop them out on a rough landing. Even seen guys rip the shock ends off...
cwalters is offline   Reply With Quote
Old 09-08-2006, 01:19 PM   #419
Thanks for the help.
Old 09-08-2006, 07:38 PM   #420
Seisick's Avatar
Default MBX5R
MBX5R READY FOR DISTRIBUITION TO DEALERS ON THE SECOND WEEK OF OCTOBER.
PARTS LIST TO US DEALERS SHOULD BE AVAILABLE AT THE END OF THIS MONTH, NO CONVERSION KIT IS AVAILABLE, HOPEFULLY THERE WILL BE!
THE R WILL REPLACE THE PROSPEC BUT THERE WON'T BE NO STOCK R VERSION, ALL PARTS TO CONVERT FROM STOCK OR PROSPEC TO R WILL BE AVAILABLE ONCE THE R COMES OUT, AS OF NOW, THE PROSPEC IS DISCONTINUED, BUT SINCE MOST OF THE PARTS ARE IDENTICAL TO R VERSION, THERE WON'T BE ANY ISSUES WITH PARTS, EVEN THE NEW ONES
SOME NEW PARTS FOR THE R, NEW SHOCK SHAFTS, SHOCK TOWERS, SUSPENSION ARMS AND MOUNTS, STEERING LINKS (SIMILAR TO PROSPEC REAR CAMBER LINKS) SERVO SAVER, TO MENTION A FEW.
IF IT DRIVES JUST LIKE MY PROSPEC AND MY MTX4, A TANK ON RAILS, SHOULD BE FUN!
HAPPY RACING
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
FS Mugen MBX5-T Prospec & MBX5-R Both less than 3 gallons! V-Spec Less than 1 gallon! ffpm46 R/C Items: For Sale/Trade 20 08-01-2008 06:27 PM
whats the difference mbx5 prospec / mbx5 r lynell90 Nitro Off-Road 6 04-24-2008 02:31 PM
Mugen MBX5 Electric Conversion, MBX5 and MBX5R Spare Parts! Cain R/C Items: For Sale/Trade 18 04-10-2008 03:16 PM
Mugen MBX5, MBX5 Pro Spec, MBX5R Differences Cain Nitro Off-Road 12 10-01-2007 10:35 AM
MBX5 or MBX5 PROSPEC? Realworld differences? Jeel Electric Off-Road 5 12-05-2004 07:46 AM
