Old 07-26-2006, 07:41 AM   #391
TonysScrews's Avatar
I was at the Nats this past weekend and was hanging out with Bob & Bobby Tillman, as well as Scott Hughes. The new shocks are the longer shocks right off the new MBX5T unlimited MT. They also have new longer springs. The shock towers are taller so you get the correct up/down travel. Scott actually ran the old stock MBX5 shocks in the A-main and was leading the race for a while before his Rx died. It was a shame as he looked to be checked out.
The new server saver and ackerman are from the truck as well. The spring is now on top and is thicker (stiffer). The latest lower front arms (have an X-brace) are generation 4 arms. They seem to be a bit harder and too well-braced by the hingepin, so they're breaking at the pillowball side. Mugen is now molding their own plastic, so a Gen 5 arm will be out shortly.
The new MBX5T looks so AWESOME! I hope to have my ProSpec version in a week or so
Tony P.
Tonys Screws LLC
http://www.tonysscrews.com
High Grade Alloy Steel Screws, Screw Kits and Mugen Parts
TonysScrews is offline   Reply With Quote
Old 07-27-2006, 08:41 PM   #392
RYAN BARNES's Avatar
Thanks for the inside scoop Tony!! And I've personally ran into Exactly what your talking about in the Gen-4 front lower X-arms, I've broken 2 arms by the pillow ball and 1 by the hindge pin, all three in light tumbles!! I've since switched back to the 3rd version arms, which I still had a few new packs of "thank goodness", and have had NO problems since!! The new truggy kit looks AWESOME and I can't wait to check one out myself!!
RYAN BARNES is offline   Reply With Quote
Old 08-04-2006, 07:01 PM   #393
Default Mugen Shock Oil?
I just picked up a used Prospec. Looking at some set-up sheets the oils are listed as 300, 350 and 400. Is this the same 30, 35 and 40wt?
Lextek is offline   Reply With Quote
Old 08-04-2006, 08:35 PM   #394
Davidka's Avatar
Trader Rating: 75 (100%+)
Nope, it is a weird scale. I can tell you from experience that every 50 in CPS is roughly 2.5wt in US calibration. I run Losi 30 or Trinity 32.5 in the rear and Losi 32.5 or Trinity 35 up front, this is almost exactly the same as 350 and 400.
Old 08-04-2006, 08:50 PM   #395
Trader Rating: 14 (100%+)
try this link
http://www.twf8.ws/php/tip/shock.html
o.s. power is offline   Reply With Quote
Old 08-04-2006, 09:01 PM   #396
Thanks guys. Nothing's easy.
Old 08-15-2006, 07:14 PM   #397
Default Brake Bias
I'm trying to play around with brake bias. Some people tell me too set them up with more rear brake. They say it helps rotate the buggy in to the corners. It seems no matter how much rear brake I dial in the front still grabs more. What about Cradock brakes?
Old 08-15-2006, 08:08 PM   #398
Trader Rating: 24 (100%+)
Craddock brakes is a no no. if your a serious racer u wont use them.
they work good for about 2 races then the hex in the middle of the brake wears out and spins around. You need reliable strong brakes with metal hex so no stripping out at all.
I run my brake bias at about 60/40. ( 60 front / 40 rear ) depends on track.
If u want quicker stopping u run more front. if ur on a grass track. run ver little front such as 30 front 70 rear. as grass offers to much grip.
" It takes a lot of things to go right, but only one thing to go wrong to lose a race "
HEI | NBHC.com | Model Engines | World Hobbies
Jarred King is offline   Reply With Quote
Old 08-16-2006, 08:41 AM   #399
The best brakes for the MBX5 are the TTRS3 option discs. They are pricey but well worth it. Bradley ran them when he was on the Mugen team as well as Tyler Vik.
I run 40/60 to 30/70 F/R bias.
Tony P.
Tonys Screws LLC
Old 08-16-2006, 01:21 PM   #400
SavageGoZoom's Avatar
Send a message via AIM to SavageGoZoom Send a message via MSN to SavageGoZoom
Personaly I like the CNR bakes... expensive but soooo nice... i got pics if you want
SavageGoZoom is offline   Reply With Quote
Old 08-16-2006, 01:28 PM   #401
Ithink part of my problem is a slightly, worn bushing for the front front brake cam. I was looking at the King Headz center diff plate with the bearings as an upgrade.
Old 08-17-2006, 03:44 PM   #402
frodo disks by fironi best I ever used they last forever with no fade
Traceyf is offline   Reply With Quote
Old 08-17-2006, 03:50 PM   #403
What are you guys running for pads?
Old 08-17-2006, 04:37 PM   #404
BringItOn's Avatar
yes the cetre pplate with bearings are great
BringItOn is offline   Reply With Quote
Old 08-17-2006, 05:08 PM   #405
With the TTRS3 option discs or the Craddocks, you just use the stock metal calipers without the blue pad glued on. Before the TTRS3 discs, I used the Craddocks on my MBX5 and MSR X5T conversion. They worked well, but I had to clean them often.
Tony P.
Tonys Screws LLC
FS Mugen MBX5-T Prospec & MBX5-R Both less than 3 gallons! V-Spec Less than 1 gallon! ffpm46 R/C Items: For Sale/Trade 20 08-01-2008 06:27 PM
whats the difference mbx5 prospec / mbx5 r lynell90 Nitro Off-Road 6 04-24-2008 02:31 PM
Mugen MBX5 Electric Conversion, MBX5 and MBX5R Spare Parts! Cain R/C Items: For Sale/Trade 18 04-10-2008 03:16 PM
Mugen MBX5, MBX5 Pro Spec, MBX5R Differences Cain Nitro Off-Road 12 10-01-2007 10:35 AM
MBX5 or MBX5 PROSPEC? Realworld differences? Jeel Electric Off-Road 5 12-05-2004 07:46 AM
