Old 06-30-2006, 08:14 AM   #361
Davidka's Avatar
Trader Rating: 75 (100%+)
To remove bump steer you must also remove the reactive caster. The upper hinge pin is not parallel with the lower hinge pin. This can be achieved by shimming down the rear upper hingepin mount to make the two pins parallel. You should then be able to shim the steering link up/down to get the bump steer out. I think with the stock setup or the widely used 2mm shimmed setup the car has a bit of bump-out (toes out as suspension compresses) this should help turn-in without instability under acceleration.
Old 06-30-2006, 12:00 PM   #362
SkarTisu's Avatar
Send a message via AIM to SkarTisu Send a message via Yahoo to SkarTisu
Ohhhh.....I forgot about the reactive caster. That's why the "bump steer path" looks so goofy to me.
I'd think that reactive caster is generally a good thing, so I guess I'll stop my quest for no bump steer!
SkarTisu is offline   Reply With Quote
Old 06-30-2006, 12:13 PM   #363
Davidka's Avatar
Chad Bradley used to always ran setups without reactive caster. I've been meaning to try it but have never gotten around to it. His setup used a middle spacer in the shock tower (for rear hingepin mount) and the lower block at the rear of the hinge pin with 1.5mm washers between the rear mount and the nose plate. The 1.5mm spacers that come with the kit for steering servo mounting look like they would work perfectly for this.
Old 07-02-2006, 08:18 PM   #364
I have a setup question.
I have been running the Scott Houghs 06 silver state setup on my track and its unreal!! True my track is very rough but the corner speed is on fire.
The question i have is it is based on a very rough track. Does anyone know what Scott's basic setup is? I go to other tracks and they are not as rough.
I looked at his old 04 Silver ST. setup and it seems the only thing changed was the shock oil and the front upper caster roll center. (moved low).
The Jason Ashton setup was easy to drive but had NO corner speed.
kyracer is offline   Reply With Quote
Old 07-02-2006, 11:12 PM   #365
Old 07-04-2006, 08:38 PM   #366
devious17's Avatar
anyone tried 7k front ,10k center ,5k rear diff oil on an dry clay track?
I tried 5k front 7k center and 3k rear and prematurey worn out 2 pairs of front tyres due to tyre spinning . This is because the straights isnt really straight so when I WOT on the 'straights' the front left tyre spins more than the right as the straight is curving slightly to the left.
The MBX5 needs a stronger front bumper me thinks.
Audio,Video, Disco
devious17 is offline   Reply With Quote
Old 07-04-2006, 10:48 PM   #367
BringItOn's Avatar
been running oiriginal bumper for 2 years. prob over 100ltires use.
BringItOn is offline   Reply With Quote
Old 07-05-2006, 10:33 AM   #368
SkarTisu's Avatar
Scott's comment on the setup sheet was that his Silver State setup was for "the roughest track ever"
Old 07-05-2006, 02:12 PM   #369
Davidka's Avatar
devious17, I would try the 7k in the front first. 8k in the center diff is as heavy a diff fluid as I have ever heard of anyone using in an X-5. I would think that the car would feel sluggish with heav fluids in all 3 diffs. Is it possible that your fluid has leaked out of the front diff? Mugen diffs are known to leak with the stock O-rings in them.
Old 07-05-2006, 06:24 PM   #370
devious17's Avatar
Thanks Davidka
Indeed the diff does leak on my X5 and I have remedied it by sealing it with gasket glue for automotive engine and got all ém O rings replaced , it hasnt leaked since.
I too was wondering if the engine would be overloaded due to the heavy diff configuration .ie sluggish.
I'll try your suggestion Davidka,saves me from having to do all 3 diff in a go
Audio,Video, Disco
Old 07-05-2006, 06:44 PM   #371
Send a message via AIM to Msand Send a message via MSN to Msand Send a message via Yahoo to Msand
Like your sig Devious, but you should add this...
"Opinions are like Assholes............everyone has one.... And they all stink!!"
I have been reading this thread and there sure is lots of info, I recently got a X5 and have been like a sponge with all the info in this thread.
Thanks to all !!
Msand is offline   Reply With Quote
Old 07-05-2006, 06:47 PM   #372
Davidka's Avatar
devious17, your engine should hardly notice the difference. By sluggish I meant the handling. Iy probably wouldn't steer or rotate very well until you stab the throttle
Old 07-05-2006, 07:48 PM   #373
devious17's Avatar
Thanks to all !!
Msand , hahahahahaha..........well, I didnt want to state the obvious so I left it a "everyone has one "
Audio,Video, Disco
Old 07-10-2006, 12:33 PM   #374
Davidka's Avatar
I don't know if it has been covered on this thread but I wanted to know about the lower front pivot blocks i.e. the -1, -2, -3 blocks. Everybody normally runs the -1 but I am interested in knowing what I can expect from changing this. It is a difficult part to change compared to other tuning options.
Thanks in advance for your input.
Old 07-10-2006, 02:18 PM   #375
Crim3Wav3's Avatar
from my experience, the -1 block gives much more off power steering than the -2...which translates to less on-power steering. Bump handling in the front is better with the -1 (due to steeper angle of the arm)...the thing you will lose with the -1 compared to the -2 is front end bite under acceleration....among others...but I wont go into too much more detail...the Mugen just loves the -1...period.
Crim3Wav3 is offline   Reply With Quote
FS Mugen MBX5-T Prospec & MBX5-R Both less than 3 gallons! V-Spec Less than 1 gallon! ffpm46 R/C Items: For Sale/Trade 20 08-01-2008 06:27 PM
whats the difference mbx5 prospec / mbx5 r lynell90 Nitro Off-Road 6 04-24-2008 02:31 PM
Mugen MBX5 Electric Conversion, MBX5 and MBX5R Spare Parts! Cain R/C Items: For Sale/Trade 18 04-10-2008 03:16 PM
Mugen MBX5, MBX5 Pro Spec, MBX5R Differences Cain Nitro Off-Road 12 10-01-2007 10:35 AM
MBX5 or MBX5 PROSPEC? Realworld differences? Jeel Electric Off-Road 5 12-05-2004 07:46 AM
