Old 03-08-2006, 10:53 AM   #166
Davidka's Avatar
Trader Rating: 75 (100%+)
That's good to know (about the shocks). I've always felt that Mugen's shocks was the one major shortcoming on an otherwise excellent car. I am thinking of putting TTR shocks on my car for this season. They are hard anodized and inexpensive. They also have the right size bore (pistons the same size)so setup should not change much.
Old 03-09-2006, 06:58 AM   #167
TonysScrews's Avatar
David,
I hear the Mayhem shocks are even better and cheaper. I'm picking up a set to try on the MSR. They are hard coated and supposed to work just as good as the JLB shocks but only 1/3 the price
Tony P.
Tonys Screws LLC
http://www.tonysscrews.com
High Grade Alloy Steel Screws, Screw Kits and Mugen Parts
TonysScrews is offline   Reply With Quote
Old 03-09-2006, 10:55 AM   #168
Davidka's Avatar
Check out the TTR shocks on Amainhobbies.com. Less than $60 for the set.
Old 03-09-2006, 11:35 AM   #169
Hi Dave,
I checked out the TTR shocks but I'm not fond of the shaft diameter being reduced from 3.5mm to 3mm where the rod end screws on to. The SportWerks shafts are 3.5mm and so are the threads for the rod end. They are also $58 for both the F&R complete sets, come with springs, preload clips and are fully assembled.
Tony P.
Tony P.
Tonys Screws LLC
Old 03-09-2006, 12:04 PM   #170
I think the mugen shocks work great and very easy to adjust.
Smooth as glass!!
kyracer is offline   Reply With Quote
Old 03-09-2006, 06:44 PM   #171
The Mugen shocks are great. Never broke or bent a shaft. But after one race day the oil is all gray from the psiton wearing the aluminum bore inside.
Tony P.
Tonys Screws LLC
Old 03-09-2006, 07:01 PM   #172
anyone use the white pistons? was told they were smoother....
XingXing is offline   Reply With Quote
Old 03-09-2006, 08:03 PM   #173
Davidka's Avatar
Black pistons are 2x 1.5mm hole. White pistons are 2x 1.4mm hole or there is another option pisotn that is 1 x 1.9mm hole. Interestingly enough, the black pistons (1.5mm) come stock with all MBX5 and Prospec kits. Mugen replacement shock kits come with the white 2x1.4mm pistons. Strange?
the 1.4mm piston will give more "pack" or high speed damping.
Old 03-10-2006, 01:11 AM   #174
Things that make you go hmmmmmmmmm.
1:The good thing is Mugen shock are easy and fast to change the shock oil out.
2:I thought the replacement shocks are not in the USA yet?
3:The 1 piston and 2 piston confuse me.
Why not change the bore of a 2 piston? Its just too deep for me.
I guess I willl have to reread my XXX Main setup book again. Not that it tells anything about piston #
Old 03-10-2006, 07:39 AM   #175
Trader Rating: 14 (100%+)
What he is saying is that the black pistons have 2 holes that are 1.5 mm in diameter each, the white pistons have 2 holes that are 1.4 mm in diameter, then the optional pistons have just one hole that is 1.9 mm in diameter.
o.s. power is offline   Reply With Quote
Old 03-10-2006, 09:55 AM   #176
So how does the 1 hole compress compared to a 2 hole piston. The 1 hole is larger by .4mm. I would guess the 1 hole would have less compression then the 1.5mm.
Old 03-10-2006, 10:18 AM   #177
Davidka's Avatar
I am not sure how that works out. I have seen a setup that Chad Bradley used the 1 hole piston but I can only guess that it causes even more pack? I've never tried it. I find that the 1.5 piston and 350rear and 400 front works very well everywhere so I must admit that I have not experimented much.
Old 03-21-2006, 02:21 PM   #178
Default conversion mbx5 to prospec
I am just getting back into racing for this summer and I have an older mbx5. I was wondering what all the upgrades are for the prospec and can it be converted easily. Car has maybe 2 races on it and is still like new so I do not want to buy a whole new car, but would like the upgrades that most affect the handling, especially the steering. I heard there were new a-arms and uprights, is this correct? Will they fit the older model? Thanks for any responses.
no4hitter is offline   Reply With Quote
Old 03-21-2006, 03:15 PM   #179
Davidka's Avatar
The only Prospec upgrades that directly effect performance are not really prospec upgrades. The front lower arms and knuckles give 10% more steering throw and the one piece engine mount prevents the clutch bell from touching the chassis in the event of an extremely hard landing (never happened to me). The rest of the parts are machined billet versions of the original parts that are stronger and heavier. Otherwise the two are functionally exactly the same. I have a standard MBX5 and since the region I race in has relatively soft dirt, I see no need for the CNC machined parts.
Old 03-21-2006, 04:59 PM   #180
Trader Rating: 22 (100%+)
Default mugen truggy
anyone hear any rumors about when or if mugen will be putting out a long arm truggy kit?
sand geek is offline   Reply With Quote
FS Mugen MBX5-T Prospec & MBX5-R Both less than 3 gallons! V-Spec Less than 1 gallon! ffpm46 R/C Items: For Sale/Trade 20 08-01-2008 06:27 PM
whats the difference mbx5 prospec / mbx5 r lynell90 Nitro Off-Road 6 04-24-2008 02:31 PM
Mugen MBX5 Electric Conversion, MBX5 and MBX5R Spare Parts! Cain R/C Items: For Sale/Trade 18 04-10-2008 03:16 PM
Mugen MBX5, MBX5 Pro Spec, MBX5R Differences Cain Nitro Off-Road 12 10-01-2007 10:35 AM
MBX5 or MBX5 PROSPEC? Realworld differences? Jeel Electric Off-Road 5 12-05-2004 07:46 AM
