How competitive is a MP7.5 in 2016?
#106
The 7.5 is more than enough to have fun the few times at the track. You will need stiffer springs which are difficult to get for the old small bore shocks, if you are really interested in racing a set of mp9 shocks and springs and their upper shock mounts will fit right on and be the biggest upgrade you can fit. I'll put a setup sheet with the best settings for me, should be a good start for you.
#107
#108
Get the competition 7.5 chassis and shock towers instead of the 777 as they are different. I have two "pro" chassis plates well used and the RTR one, no comparison in strength. Should still be some on vendors. Later today I'll attach the sheet. The fioroni was good too!
#109
Yes I pulled the trigger on that Fioroni years ago and got it for a steal at around $60 - now there are no more competition products left for this buggy but any oem chassis you find is $$$$. I searched for hours for a decent chassis ignoring pricing. Fioroni dumped the item, can't find any others at all when scouring the internet. This is really my fear about this car, everybody telling me it's a good buggy and not to upgrade unless I race - but I can't find parts anymore. NEO is the same but companies no longer care about RTR models so they've dropped compatible product lines. I looked up "competition rc" and found nothing. Is competition a name or were you just using it generically?
#111
Yes generic term as the 7.5 is mostly know for RTR. I have a shop that say they have the race/competition chassis available, this. Can't seem to find my setup sheet, well the changes where mostly on the rear end.
#112
If not mistaken the hyper 7 spur is compatible.
#113
Yep no luck finding it... So here goes the changes, rear camber link using the inside hole on the upright, -1 camber and top hole on the bottom of the upright. Front 2.1mm roll bar, B kick up parts (think it's stock...) and front holes on the steering rack.
#114
I have a torsen diff intended for a 7 that I think it fits, only put both diffs side by side for the moment...
About wear, the drivetrain is very good. This car has had at least 10 gallons through various engines and everything is still fine, the cardans are a bit sloppy and outdrives showing wear but otherwise very good car.
The tki4 is a better car but in my opinion too lightweight, front end could be stouter like the 7.5.
#117
HPI too I think.
#118
