Kyosho Inferno MP9 TKI4 1/8 Buggy Kit
#2101
Hi guys,
Novice racer here, keen to try the TKI4 setup at the top of this thread(the Wiki one) on my spare buggy to compare to my current setup.
My questions is, What settings do I use where the setup sheet is not filled in?
#2103
Great! I will keep a look out for the complete setup sheet. Currently running a Tebo setup(which is all I have ever ran with minor tweaks). Might be a couple of weeks before I can run the two cars back to back, I will diffidently report back to give Novice drivers perspective
#2104
Thanks, appreciate it.
This is the complete setup, is just me or there isn't a place to put which kick up one is running? Mine is the A plate pills dot up (9º).
About the setup, the 2.6mm front roll bar might not be needed (used to give more turn in and keep front tire wear better balanced R-L), for ride height it's imperative arms level, if 28mm RH gives you level arms then do it. I'm also eager to find if 13º hubs have enough adjustment to keep you all from buying more hubs, don't forget to add 1mm shim under the pivot ball on the steering arm if you run -1 caster bushing. Orange rear springs have a better balance than light blue all round, maybe grey fronts and light blue rears if you want a stiffer car all round, so the balance is softer=light blue front and orange rear, stiffer=grey front and light blue rear. Which one you use will depend on the temperature of the tires, stiffer for more heat into tires and vice versa.
Whoever uses TKI3 knuckles is a rotten egg. TKI4 arms have the steering arm further into the wheel so the linkage has better geometry during racing conditions.
Almost forgot, doesn't matter if TKI3 or TKI4, 9º of kick up for medium traction tracks, 11º for very low and 7º for high grip.
Ask away.
Ask away.
#2105
Ask away.
Ask away.
Kick up is set on the "Lower", "front side" on the setup. I don't know why would you run less kick up on high grip, 11º gives me the best feeling at most conditions.
Tki3 nuckles give a better ackermann feeling, for me at least.
On low grip try the long grey spring on front and orange spring on the rear, that's what I always run.
Is anyone interested on my high grip and also low grip setups? They differ kinda a lot from 30tooth's setup. I can share them if you want.
Edit: The toe and the wheelbase settings on your setup is pure madness to me.
#2106
i appreciate 30tooth efforts but dont always agree with his setups having tried them
#2107
The amount of kick up is directly related to the amount of pitch you want, more kick up more pitching. Pitching is good, that means the front is low to the ground during off power, increasing turn in. The real issue is that with increasing grip that pitching becomes too much and transfers even more weight to the front, off loading the rear and overloading the front. That's against the intent of this method, high travel low roll.
They should, the old knuckles are more aggressive in Ackerman steering. The TKI4 knuckles are less aggressive and that allows me to setup the car around less static toe front and rear (more free rolling). Speaking of that, once I found that stiffer rear end in roll provides more grip than static toe all my cars now run less rear toe (JQ,XB9,MP7.5,MP9, the Mugens), it works for me and I had others drive my cars without much complaints.
As I have weighted the car and have almost real rates of the springs those are the combos I live by, please give your low grip setup with thicker front bar than rear instead of those springs a try, see if it works for you.
I'm interested in the setups, don't be shy.
There's only two gentlemen (both at extreme temperatures, one is a top Swedish guy and you) that relayed negative feedback from my setups. In hindsight I should increase front shock oil to 600cps or recommending the middle holes on the steering plate to gain a more supported front end as I think that's the culprit. Can you specify what are your issues when you try the setup I developed? Thanks for recognizing my work.
#2108
I'm tempted to buy a Spec-A. Has anyone bought one and can comment on quality of the build etc.?
thanks
thanks
#2110
Ah I see now. Disregard as I'm very tired. Allow me explain my setup methodology.
I agree, older nuckles are more agressive, but they also give a better steering response. I see a point with the decreased rear toe, but it doesn't suit me and many others in my experience. I can't currently test your theory on low grip, but I just told which works the best for me. Im my opinion rear swaybar can't ever be thinner than the front one.
This is my low grip setup. I'd like to explain a few things, but feel free to ask anything.
Diffs: Front diff I usually use 5k-7k depending on how much steering or forward drive I need. Center diff is pretty self-explanatory, Usually I'll use 6k or 7k, 5k feels too soft everywhere. Rear diff: this is different, because I feel like a higher oil makes the rear have a lot more forward drive, but it helps to do 180° corners , by having more steering in the middle of the corner. It makes accelerating out of the corner much easier too.
Shocks: The front piston is the stock one (1.55) drilled to 1.6. This gives me the best feeling on the front end, but you need to run stiff oil in it. 800 is good for 15 ° C, then if needed I run even stiffer oil (1k). Rear pistons are pretty much what everyone else runs, but the oil is supposed to be like 500 not 600.
Toe: front is considered as "stock" and rear too.
Wheelbase: 1mm in the front gives the car better turn in in 180°, but takes away forward drive. 2 mm in the front is what I run every else, if it's not too high grip. More mm in the front makes the car a bit more stable.
Everything else is in a way considered "stock", but I like to run 17° caster and the higher front link, because our tracks are usually bumpy.
#2111
This is what I currently run, on super high grip smooth concrete.
Diffs: 15k-20k-10k currently feels like a solid choice, although the center diff should be thicker. Maybe even 50k. Rear diff could be higher, but the track has some parts where the is more slippy concrete, so thicker oil makes the rear unstable at those parts.
Shocks: same piston as in low grip, but much thicker oil.
Wheelbase: more mm in front to get more forward drive.
Rear link: Longer link gives more stability and the middle hole takes away rear grip, compared to the lower hole.
Anti-squat: More is better on high grip.
Sway bars: Just because of the grip, Sway bars are thicker, but I don't like the front one too thick (2.8). I'll have to test the new 2.7 once I get my hands on one.
Otherwise same as the low grip setup.
#2112
Add them to the wiki please.
About the kick up and B plate pills, do you have them that way or it's a mistake? Why the big difference in piston hole sizes?
Once I have more time I will give your low grip setup a try, it doesn't stray far away from the TKI3 Spec A setup which I have tested thoroughly.
#2114
I use arm sweep (pill outside) at most tracks, which adds more steering.
I liked the 1.5X5 hole in the rear too, but it can't handle bumps at all. So I just switched to what I ran before on the rear. I previously only ran 1.3X8 all around, with 650-450 oils.
I have tested every change from this setup at our local tracks multiple times and it's what was best at the end of summer.
You can't really a say any setup works at a certain track, because there are always going to be differences, but this my "base-line".
I can't edit the wiki, because this is a brand new account, I would need 90 days and 90 replies...
#2115
When I generally need more steering and the track is flat enough, I just go down on the caster to 14 degrees (13+1) normally I'll use either 15 or 17. Caster isn't something that you need to really compensate with other things. Just like many other things, compensation is more like cancelling the change you are making. If the caster changes the feeling too much, a thicker front sway-bar makes the front of the car more stable.
