To failsafe or not?
To failsafe or not?
Hey there guys. Ok I would like to know if I should run an external failsafe with the Futaba 3PL 2.4g I was only $125 so I'm not sure.
I do have the hpi mico failsafe just don't know if I should install it or not? What do you guys think. the radio does have a built in failsafe also. should I run both or just the radio or just the external one.....confused......
Never use a external failsafe if the transmitter has one.
A failsafe starts to work when there is no signal.
If the failsafe from the TX/RX set drops in there will be still a signal so the external failsafe will do nothing. And why would you use an external failsafe if the transmitter already has one? More electronics is also a higher chance of errors.
no failsafe
i use a throttle return spring strong enough to pull the carb closed if the servo loses power, it will also hold the carb closed if the linkage falls off the carb. most modern radios just stop sending power to the servos when they loose signal. if a servo fails and locks no saftey device will save the motor or car. back in the late 2000s allot of guys were smoking servos by setting failsafes to full brakes
