So what is the best clutch system.......
I've been running m2c lightened system & been having issues with them.... One of the pins that holds the shoes in place broke. Then the nut that holds the clutch on the crack, was tightened and broke the housing of the clutch in a qualifier. Because I had a flywheel spin on a collet which was not as tightened was the only reason it was that tight. So been looking at other systems like the Reds/Nova, Buku, or the old stock clutch system. Thanks for your input on this!
Hands down buku. Will you be at the track Saturday? Come see me and I'll walk you through the buku setup and you'll never look back.
Sure will be there. Got to pick up my bodies from mark. And try a new clutch system out. Lol
I like the BuKu also.very easy to work with.
Buku is the way to go. I've lost count how many gallons I've ran on the same set of shoes and its still working great. On top of that, clutch bell does not wear at all and the $1 bearings lasts much longer than in a standard clutch. Adjustment for track condition is a breeze. Usually only take an 1/16 or 1/8 of a turn here and there to get the clutch feeling perfect. Just make sure to blow out the grease in the new clutch bearing before use to avoid ruining the shoes then you are good to go. In my opinion, going buku has made running nitro much more enjoyable just for the reduced effort in clutch maintenance alone.
I like HPI's teflon clutch shoes for general use, on-road or off-road. (I tried aluminum shoes and I didn't like all the crap they deposited on the inside of the clutch bell.) Teflon shoes can slip a lot if the terrain is rough and they won't overheat anything. (useful for climbing over curbs, which is something I do on a regular basis.) However, I have a BuKu adjustable clutch with "Komposite" shoes on my T-Maxx, and it's an excellent clutch -- the adjustability really makes a big difference in tuning-away the stuttering that the T-Maxx suffers from when starting from a stop. I suppose if I were going to race, I'd go with the BuKu Komposite clutch, assuming I could get one to fit whatever vehicle I wanted to race, but otherwise HPI's teflon shoes work great. I haven't had to replace a set on any of my nitro vehicles yet.
As for clutch bearings, I use only Boca Yellow Seal ceramic bearings, and whichever bearing is going to be facing the inside of the clutch bell, I pull the seals off and spray all the grease out with CRC electronics cleaner, then reinstall the seals. That ensures the grease won't leak into the clutch bell and foul the shoes. (I learned that the hard way.) The ceramic bearings are good enough that they can run smoothly for several seasons even with no grease at all. I wouldn't do that to bearings with a harder workload, but for clutch bearings it works great.
Buku is awesome. I've been using a novarossi lately and it's great as well.
Buku hands down. my flywheel has been in 3 cars and has well over 15 gallons on it. Bearing life is unreal, shoes last almost 5 gallons. It pays for its self by the 2nd gallon. and track adjustments take about 15 seconds...forget about the time spent on clutch work and focus on other things.
Setting the buku on the soft end I felt worked well at low bite tracks like Revelation.
