TLR 8ight 4.0
#961
Yes. I do race on several larger indoor and outdoor tracks. Honestly, the setup doesn't change much if any. Keep in mind it was super cold on the day of that setup sheet. Normally shock oils will be more like 35/30.
#962
And you like the emulsion setup better the bladder? When I raced my 2.0 the bladder worked great. Never heard of emulsion until now.
#963
#965
Do you guy's use the DE extreme rear skid pads? I remember using them back when I had the 2.0, but don't remember if they're worth using.
#966
#967
#969
My personal preference is max/most caster as it seems to be more forgiving and easiest to drive.
#970
TLR 8ight 4.0 Chassis Cracks
I've been experiencing -
a) Recurring cracks between the two front engine mount bolting points & flywheel opening (on both my previous TLR 8ight 3.0 & now on my 4.0 - initial chassis & the second chassis).
b) I did contact Horizon Hobby & they noted they are not seeing the same issue.
Has anyone else experienced similar issues? If so, were you able to come up with a solution to eliminate (short of switching to another brand) the cracks?
Perhaps this problem is due to the chassis flex (apparent from clutch bell pinion gouging of fuel tank) in addition to metal fatigue associated with heating/cooling cycles underneath engine mount? On all of my TLR vehicles that I've owned, I've noticed what appears to be considerable chassis flex... not a lot of rigidity.
If anyone has any solutions, I'd appreciate your thoughts. Thanks.
#971
Yes its from chassis flexing in that area. Which begs me to ask, do you come up short on a lot of jumps? Do a lot of lawn darts? Flat bottom a lot? What chassis braces are you running? If its the aluminum ones...theres your problem. They look good, but are too stiff and cause issues ( DING DING DING!!!). Are you running any other aftermarket parts on the car? Motor mount? Center diff mount?
After almost 15 years with Losi, and 20 or so 8 series vehicles... I have yet to do this myself. I think you need to get a job in the testing/ durability department
#972
I have seen that once or twice and experienced it on another brand myself (Ofna Jammin Truggy but it was fixed with their "Z" brace)
I've ordered another chassis & some other goodies to get the vehicle properly sorted out & back on track for some club racing.
#973
I don't know and this is only a thought, but is it possible to be putting to much downward pressure on the starter box flexing the chassis.
#974
Hah... I don't run any structural aluminum parts other than the TLR servo saver top plate, all other structural components are kit/stock. The only thing I can think to do at this point is to stiffen up my suspension a bit, I can't think of anything else.
Weird...I don't know what to tell you.
You could look and try to find a King Headz extended QC motor mount. Other than that, run it till if breaks in half
#975
After 7 long years I pulled the trigger and bought a Losi 4.0 last Tuesday and put on the track on Sunday. What a blast it was to be on the track. I'm a little rusty, but I'm sure it will come back fast.
