Old 07-29-2008, 06:21 AM   #946
bgbelden's Avatar
Originally Posted by SIXPAC View Post
pretty sweet... drop the ride height and you got CORR truck!
just picked up a used Matrix... u guys run the proline mugen body?
thx.
Crowdpleaser 2.0
''Life's tough ........
it's even tougher if you're stupid..''
-- John Wayne
bgbelden is offline   Reply With Quote
Old 07-29-2008, 06:58 AM   #947
Here's my buggy after running on some mud..
It took me forever to clean this thing.. I wonder what do you guys use to clean your buggy after racing on mud? I heard some simple green and alcohol will do the trick..
pedsaktix is offline   Reply With Quote
Old 07-29-2008, 01:34 PM   #948
dahlelama's Avatar
Simple Green definately. Never used alcohol.
I take the motor out and the radio tray out and clean those by hand. Then scrub the chassis parts with simple green and hot water and a stiff toothbrush. Rinse it off. The key is to blow it off with a compressor to dry it.
Getting that plastic looking good again... you can use WD-40 (spray it on and wipe it off). Or, there is some automotive exterior trim cleaner that you can buy at Walmart or any auto supply store. Can't remember the name but there are a couple brands. You'll recognize it when you see it.
e.
Eric
Remote Control Hobbies Boise
Boise, ID
208-658-4500 |boise@rc-hobbies.com
dahlelama is offline   Reply With Quote
Old 08-01-2008, 08:29 PM   #949
Originally Posted by dragonman View Post
If you look back on page 31 there are pictures of the team Cen guys buggys at the Nats. In the pics you can see what they are doing with their wing mounts. They are using radio tray posts instead of the long wing mount posts to create a narrower wing mount and it also lets you use a high downforce wing because of the narrow bolt pattern of the modded mount . you must heat the wing mounts a little bit to get them to bend in.
you can use the stock cen radio tray mounts and just bolt them on in between the plastic cen wing mounts and let them bend its ok you do not need to heat them up we all ran them like that at the nats with no problems
go really fast and turn left....
Robert.Hull is offline   Reply With Quote
Old 08-01-2008, 09:16 PM   #950
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
I just did that mod yesterday and the result its awesome, cartwheeled on demand and the wing stayed 100% ...
cya,
Patricio "PATO" Concha
E-Mail : pato_concha@yahoo.com
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 08-02-2008, 01:14 PM   #951
Default setup
quick question for you guys, my matrix is nose diving off every jump I hit. I'm still learning about setup and I'm not 100% sure what direction to go to correct this. Blipping the throttle in the air helps, but it should fly straighter on its own. Help please!!!
Trail Bruizer is offline   Reply With Quote
Old 08-02-2008, 04:01 PM   #952
j_blaze14's Avatar
Trader Rating: 34 (100%+)
pop the wing up a notch for more down force.
j_blaze14 is offline   Reply With Quote
Old 08-02-2008, 04:48 PM   #953
pinky2252s's Avatar
Send a message via AIM to pinky2252s Send a message via MSN to pinky2252s
Can you guys help me with my new thread? thanks
Procrastinators Unite!.....Tomorrow
Team Terribles
pinky2252s is offline   Reply With Quote
Old 08-02-2008, 06:07 PM   #954
Trader Rating: 21 (100%+)
Tell us more about your setup. This way we can help you go in the right direction.
Just guessing, it sounds like your rear shocks are too soft, or the ride height isn't right causing the rear end to slap the face of the jumps causing it to nose down over the jumps.
Colin
Time Zone Raceways www.Timezonehobbies.com
www.ColinBranch.com
C Branch is offline   Reply With Quote
Old 08-02-2008, 06:27 PM   #955
My setup is quite simple, box stock rtr. I just put some preload spacers all around, maybe that will help, haven't run it yet though.
Old 08-02-2008, 09:08 PM   #956
TRArena's Avatar
check your brakes are not engaging at idle as well - if this is happening then as soon as you roll the jump and release the throttle the brakes may be binding and causing the nose to drop.
TRArena is offline   Reply With Quote
Old 08-02-2008, 11:09 PM   #957
make sure your brakes are not dragging and are completely free
Old 08-03-2008, 08:07 PM   #958
Trader Rating: 26 (100%+)
Hey you should check to make sure your brakes arn't dragging
bobf24 is offline   Reply With Quote
Old 08-06-2008, 09:22 AM   #959
Mcran's Avatar
Thicker shock oil and/or smaller holes in the shock pistons will help it jump better. Give and take.
Team Associated, LRP, Reedy, Hobbico - www.hobbico.com,
JConcepts - www.JConcepts.net, Futaba - www.futaba-rc.com,
OS Engines - www.osengines.com, Kal-Gard - www.Kalgard.com,
Murnan Modified Motors - www.Murnanmodified.com
Mcran is offline   Reply With Quote
Old 08-11-2008, 08:14 PM   #960
Trader Rating: 49 (100%+)
trying to sell my cen matrix fre buggy...
FS: Cen Matrix FRE.. Almost new. great mods
cleblanc is offline   Reply With Quote
CEN MATRIX FRE helivaguy Nitro Off-Road 4 08-27-2008 05:52 PM
RB 12 Matrix Matt Russell Australia For Sale/Trade 2 02-11-2008 04:31 PM
Cen Matrix dieseldog20 R/C Items: Wanted to Buy 0 02-06-2008 05:31 PM
Matrix and Matrix TR Factory Race Edition Kits SmoothB R/C Items: For Sale/Trade 4 05-31-2007 05:36 PM
Dye matrix 5 and DYE matrix 4 w/ tanks and halos for sale yuk17bandit Other Items: For Sale/Trade or Wanted to Buy 0 11-07-2006 10:49 AM
