Old 05-08-2008, 09:43 PM   #871
if you wobbly the shock back and forward it can rub at some point
go really fast and turn left....
Robert.Hull is offline   Reply With Quote
Old 05-13-2008, 10:42 AM   #872
Any of you folks want to sell your CF tower.. or any carbon part for this truck Let me know
pedsaktix is offline   Reply With Quote
Old 05-13-2008, 06:49 PM   #873
Trader Rating: 42 (92%+)
TTT
icemandolmite is offline   Reply With Quote
Old 05-15-2008, 12:16 PM   #874
Will the Losi 8ight shocks fit with this buggy?
Old 05-15-2008, 01:48 PM   #875
I actuall just bought a set to try. I measured mine compared to what losi specs show and the fronts are about the same lenght but the rear are about 5mm shorter on the losi. I think I will be able to get away with just using the lower holes in the tower. When I get it together I`ll update.
A friend of mine is running the jammin Big Bores on his buggy and truggy.
RYAN MCKAY
Owner / Operator of The BarnYard. 1/5 outdoor, 1/8 out/indoor, 1/10 indoor.
teamcracing.net
sweepracingusa.com
smc-racing.net
fuzz86 is offline   Reply With Quote
Old 05-18-2008, 08:47 PM   #876
Let us know how it turns out.
Old 05-18-2008, 08:57 PM   #877
Mcran's Avatar
We are running the Jammin 16mm Super Big Bore on the buggy. Silver springs and 1.4 pistons F/R with Losi 40 Front and 35 Rear. We ground about 3mm off the Jammin shock post so the shock would be more upright. Buggy is really, really good.
TR: 1.4 F/R with Losi 60 front and 45 rear. Gray springs in the front and blue in the rear.
Team Associated, LRP, Reedy, Hobbico - www.hobbico.com,
JConcepts - www.JConcepts.net, Futaba - www.futaba-rc.com,
OS Engines - www.osengines.com, Kal-Gard - www.Kalgard.com,
Murnan Modified Motors - www.Murnanmodified.com
Mcran is offline   Reply With Quote
Old 05-20-2008, 12:18 PM   #878
MikaR's Avatar
Hi, today started building my new Matrix Pro. It's been around 2 years since I bought my first Matrix Pro. Driveshafts seem a bit improved, so is the main gear and front upper turnbuckles (longer and more robust). Naturally this new kit came with cross-pin diffs.
The only disappointment so far was that the lower hole of the other front shock body wasn't machined completely thru so I could not put the o-rings in place. Not a big deal since I got some spares, but will send this back to the local CEN dealer.
MikaR is offline   Reply With Quote
Old 05-20-2008, 01:04 PM   #879
Im almost done building this buggy.. now I need to get a body for it. Any suggestion? and can someone post a list of body that'll fit with this truck..
Old 05-22-2008, 05:57 AM   #880
Default Threaded Hinge Pins
Were can I get a set of Threaded Hinge Pins for my cen matrix? Other brands fit?
dragonman is offline   Reply With Quote
Old 05-22-2008, 08:00 AM   #881
Send a message via AIM to JustinD
It really easy to make your own setup work I put little holes so I can fit set screws and put a notch on the pin so the set screw will hold it tight no problems.
EB MODS
Mugen MBX6 -EB MOD OS V-Spec / EB MODS FUEL
JustinD is offline   Reply With Quote
Old 05-22-2008, 09:41 AM   #882
Tree's Avatar
Send a message via ICQ to Tree
You can get threaded hinge pins at CarolinaRC
http://www.carolinasrc.com/Webstore/...idproduct=3402
http://www.carolinasrc.com/Webstore/...idproduct=3401
Cen doesn't make any for the outer part of the arms. I don't know what other manufacturers would work on the outer arms. You can do what JustinD said and use another screw to hold the pin in.
http://www.truggyracers.com/forum/in...0&#entry121969
Team Holy Rollers
HiTec Servos
"N-Tune" Nitro Engine Tuning Dials
Tree is offline   Reply With Quote
Old 05-22-2008, 09:44 AM   #883
tonyy's Avatar
Send a message via AIM to tonyy
get the new Parma body works good and looks good i will have pics up of my body
Sponsors:
www.cenracing.com
www.teamParma.com
www.EBmods.com
www.integy.com
www.motorsaver.com
www.arcshobbies.com
www.paintmonsterairbrushing.com
tonyy is offline   Reply With Quote
Old 05-22-2008, 09:52 AM   #884
tonyy's Avatar
car was just in a 45min amain!
Sponsors:
www.cenracing.com
www.teamParma.com
www.EBmods.com
www.integy.com
www.motorsaver.com
www.arcshobbies.com
Old 05-22-2008, 11:30 AM   #885
Great looking body Tonny... Does the Hyper 8 bodies will fit?
CEN MATRIX FRE helivaguy Nitro Off-Road 4 08-27-2008 05:52 PM
RB 12 Matrix Matt Russell Australia For Sale/Trade 2 02-11-2008 04:31 PM
Cen Matrix dieseldog20 R/C Items: Wanted to Buy 0 02-06-2008 05:31 PM
Matrix and Matrix TR Factory Race Edition Kits SmoothB R/C Items: For Sale/Trade 4 05-31-2007 05:36 PM
Dye matrix 5 and DYE matrix 4 w/ tanks and halos for sale yuk17bandit Other Items: For Sale/Trade or Wanted to Buy 0 11-07-2006 10:49 AM
