Old 04-18-2008, 03:13 PM   #841
Trader Rating: 26 (100%+)
if you are on a budget, I would try the stock pipe first, it should work fine and would save you some cash,
bobf24 is offline   Reply With Quote
Old 04-19-2008, 11:36 PM   #842
MikaR's Avatar
Pato, how was the race?
MikaR is offline   Reply With Quote
Old 04-20-2008, 09:21 PM   #843
Trader Rating: 49 (100%+)
pato. what up with the diffs? are those kyosho? why?
cleblanc is offline   Reply With Quote
Old 04-21-2008, 03:46 PM   #844
tonyy's Avatar
Send a message via AIM to tonyy
What bodys will fit kyosho 777 body work?
Sponsors:
www.cenracing.com
www.teamParma.com
www.EBmods.com
www.integy.com
www.motorsaver.com
www.arcshobbies.com
www.paintmonsterairbrushing.com
tonyy is offline   Reply With Quote
Old 04-21-2008, 06:58 PM   #845
SP2 will fit, or MBX5, I personally like the Mugen better as they come with bumps for the brake linkages, (proline anyway)
Old 04-23-2008, 03:23 PM   #846
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Give the Parma Xciter a try, awesome fit, low profile and light ...
cya,,
Patricio "PATO" Concha
E-Mail : pato_concha@yahoo.com
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 04-23-2008, 03:25 PM   #847
Tabushi's Avatar
Race Report
Driver : Patricio "Pato" Concha
Event : 2008 Southamerican Championship - Caracas/Venezuela - "La Lagunita" Track
Event Schedule : 1 free practice day, 1 controlled practice day and 2 race days (1 x qualifying + 1 x mains)
Format : 100% IFMAR Tree format
Result : 21th General position, from 50 drivers from 5 countries, went out finishing 4th place on the 1/4th finals (just 3 make the bump up)
Car : CEN Matrix FRE
Engine : GO Tech - 7 Ports .21
Pipe : GO Tech FEMCA 0801
Tyres : VP PRO - 802 Soft
Air Filter and Clutch Bearings : Power Save Racing (Germany)
Clutch : M2C Racing 4 Shoe model - 1.0 x 4 springs + Regular Medium Shoes
Body : Parma Xciter
Fuel : Maxy's Fuel 25%
Car Setup :
Diffs : 5k - 5k - 1k (ofna)
Transmission : 43/10 - 44 - 43/10
Clutch Bell : 16T
Shock Oil : 45wt / 35wt (associated)
Shock Springs : Mugen Grey front and rear
Front Upper Arms : Dismissed, replaced by direct links to the shock tower
Ackerman : Mid Hole
Shock Towers : Stock CF front and rear
Front Toe : Out 1º
Rear Toe : 3T/1S aluminum piece
Camber : 2º Front - 3,5º Rear
Wheelbase : 6mm inserts on the front of the rear hubs
Rear Links : Out on the hubs, lower inner hole on the shock tower
Front Shock Angle : Out on the arms, inner and up on the shock tower
Rear Shock Angle : Out on the arms, inner and up on the shock tower
Comments :
CAR (CEN Matrix FRE) : Just very happy with it, it was a 3 1/2 days process to "know" the car (first time ever touching dirt was on that race), felt guilty for not having the time to know the car before the race. The initial setup was 180º different from the final setup, wich i liked very very well (posted up on this text). My offroad experience prior to get the CEN car was almost 3 years of MT (Tamiya TNX and Losi ones) and Jammin FTE Buggy, and i must say that im very surprised by the performance of the CEN buggy, the setups are very different of what i used on the jammin, but its a very stable and fast with a high rotation capability and great jumping, waaay more agressive than my jammin and very good on the feeling of every change you do on the setup. Thanks CEN USA for giving me the chance of raceing for you, hope to give better results during this 2008 season.
Engine (GO Engines .21 7 ports) : Just amazing. One of the fastest on the straight even with the 7mm restrictor, great kick for technical sections and 8 minutes and 45 seconds of run time. Not a single flameout during the whole event, not a single sign of hesitation or anything, just due to a pitman mistake, my 1/4th finals started a little rich and he tried to solve that during pit entries. The pipe combination was very very good and it seemed that the clutch setup was perfect for what i needed from this engine. A lot of people were interested on see my engine and in fact a very well know southamerican modder ended asking me permission and opening my engine for see what was inside , he was very pleased with what he saw and gave me a "congrats" about it.
Tyres (VP PRO 802 - Soft) : Very very good choice. I tried the adviced tyres for the track (Panther Gator Soft and Proline CF M3) but when i fitted the VP PRO 802-Soft the car was on rails and with a very good wear rate. I hope you guys in USA and other countries have the chance to test them out, keep an eye on the new 804 tyre in soft and medium compounds !!.
Clutch (M2C 4 Shoe) : I selected the regular mediums for this race, with 1.0 springs x 4. Excellent choice, great response and very very low wear rate, in fact i dissasembled the whole clutch setup just for checking it and its almost new after more than 5 hours of use.
Air Filter and Clutch Bearings (Power Save Racing) : Great products as usual, the track had a little dusty condition and a lot of drivers had clutch bearing problems, i used the Power Save Racing ones and i just changed them once just for precaution but they are almost new without problems. Filters as usual worked flawlesly, best air filters i ever used.
Here you have couple videos a friend took of my CEN on the track during 1/4th finals. Maaaaaaaan that stop and go i received on the start made me crazy now im watching it, any opinion about it ?, well applied ?, i lost the chance to go for semifinals by 2 seconds, and the stop and go was 10 seconds so do the math :
First Part : http://www.revver.com/video/838562/2...-fre-01-of-02/
Second Part : http://www.revver.com/video/839160/2...-fre-02-of-02/
Soon i will be publishing more videos of the race with shots from the finals and all ...
Thanks to all my sponsors, this is my first big event of 2008 season, hope to make it better for all you next time !!!
cya !!
Pato Concha
CEN Racing
Maxy's Fuel
Power Save Racing
VP Pro Tyres
GO Engines
Upgrade RC
M2C Racing
Pits Hobby Shop Colombia
Old 04-28-2008, 03:39 PM   #848
Tabushi's Avatar
Here are the videos i edited from the last Southamerican Championship (2008 - Venezuela) ... enjoy ! :
Video 01 : CEN FRE (Pato Concha's Car) on 1/4th Finals : http://www.revver.com/video/838562/2...-fre-01-of-02/
Video 02 : CEN FRE (Pato Concha's Car) on 1/4th Finals : http://www.revver.com/video/839160/2...-fre-02-of-02/
Video 03 : Semifinals Video 01 of 02 : http://www.revver.com/video/841812/2...semifinals-01/
Video 04 : Semifinals Video 02 of 02 : http://www.revver.com/video/842289/2...semifinals-02/
Video 05 : Finals 01 of 02 : http://www.revver.com/video/847834/2...mps-finals-01/
Video 06 : Finals 02 of 02 : http://www.revver.com/video/848782/2...mps-finals-02/
cya !!
Old 05-03-2008, 10:39 AM   #849
Default Matrix FRE buggy Upgrades
What upgrade parts should I put on my FRE kit when building it? and what's a good base line setup for a high bite track that's not very rough.
Thanks in advance
dragonman is offline   Reply With Quote
Old 05-03-2008, 11:43 AM   #850
Tree's Avatar
Send a message via ICQ to Tree
Thanks in advance
If your kit didn't already come with Gene Hickerson's hardened cross pin conversion the get these:
http://cgi.ebay.com/CEN-Matrix-TR-Ar...QQcmdZViewItem
Upgrade to the CNC aluminum steering bellcrank:
http://www.amainhobbies.com/product_...ducts_id/12819
Upgrade to the CNC Steering knuckles:
http://www.amainhobbies.com/product_...ducts_id/12791
For set-ups check the CEN Racing website:
http://www.cenracing.com/race/setup.html
Team Holy Rollers
HiTec Servos
"N-Tune" Nitro Engine Tuning Dials
Tree is offline   Reply With Quote
Old 05-03-2008, 05:12 PM   #851
TRArena's Avatar
a
TRArena is offline   Reply With Quote
Old 05-03-2008, 05:56 PM   #852
TRArena's Avatar
Originally Posted by Tabushi View Post
Race Report
Thanks for the vid links and info Pato – very cool. Was the stop - go because your pitman touched the back of the car during 'down and quiet' or because your car rolled prior to the start? Bit rough either way esp considering the impact it had on your semi chances.
Old 05-04-2008, 07:35 AM   #853
tonyy's Avatar
just 2 pics of me car
Sponsors:
www.cenracing.com
www.teamParma.com
www.EBmods.com
www.integy.com
www.motorsaver.com
www.arcshobbies.com
Old 05-04-2008, 07:35 AM   #854
tonyy's Avatar
just 2 pics of my car
Sponsors:
www.cenracing.com
www.teamParma.com
www.EBmods.com
www.integy.com
www.motorsaver.com
www.arcshobbies.com
Old 05-04-2008, 07:45 AM   #855
Send a message via AIM to JustinD
I drove my buggy yesterday at the NRL (Nitro Racing League) Series at the Tiltyard in Virginia qualified 6th Started the main jumped up too 3rd battles with the leaders for about 5 minutes than I left the field got a 16 second lead of Team Losi drivers and Team Kyosho drivers in my area it was pitch black and I flew off the track than I battle a Team Losi driver for the rest of the race to come up leading the last lap but traction rolling to only get 2nd.My car was awesome get great and made alot of haters shut there mouth for talking so bad about it.
P.S it was my 2nd race with the buggy against other pro drivers that has had the car over a year.
EB MODS
Mugen MBX6 -EB MOD OS V-Spec / EB MODS FUEL
JustinD is offline   Reply With Quote
CEN MATRIX FRE helivaguy Nitro Off-Road 4 08-27-2008 05:52 PM
RB 12 Matrix Matt Russell Australia For Sale/Trade 2 02-11-2008 04:31 PM
Cen Matrix dieseldog20 R/C Items: Wanted to Buy 0 02-06-2008 05:31 PM
Matrix and Matrix TR Factory Race Edition Kits SmoothB R/C Items: For Sale/Trade 4 05-31-2007 05:36 PM
Dye matrix 5 and DYE matrix 4 w/ tanks and halos for sale yuk17bandit Other Items: For Sale/Trade or Wanted to Buy 0 11-07-2006 10:49 AM
