Old 03-27-2008, 04:38 PM   #811
It is more possible when using the outer hole on the arms. I have only used them 1 time - in Brazil. There was a tripple on the back straight that was hit at full speed, but I never poped a CVD even flat landing it. Stange. Maybe because I usually use -3' camber?
VP-Pro USA - www.raceVPpro.com
Agama USA - www.AgamaUSA.com
Maxy's Fuel - www.Maxysfuel.com
Machine's R/C H is offline   Reply With Quote
Old 03-27-2008, 10:09 PM   #812
MikaR's Avatar
-3 camber cenrtainly helps. I use always inner holes on the arm.
MikaR is offline   Reply With Quote
Old 03-28-2008, 07:07 PM   #813
Default wing mount
This may be stupid question, but can you use any other wing mounts, or must you use the matrix wing mount? Thanks
nayslayer is offline   Reply With Quote
Old 03-29-2008, 12:41 AM   #814
MikaR's Avatar
Hi, I don't see a way to use any other wing mount than the stock unless it's similar.
Old 03-30-2008, 07:39 AM   #815
mugen will work but you have to use cen post and shave a couple things and on the shocktower you have to use the bottom wing mount hole and that slot thats there you run a nut and bolt with a washer and its built like a tank
go really fast and turn left....
Robert.Hull is offline   Reply With Quote
Old 03-30-2008, 01:03 PM   #816
thanks again robert, the reason i ask is that i busted through a few holes on the wing adjustment piece with the holes.Not the mount itself, but the two adjustment pieces...heh, i guess i spent alot of time with buggy wrong side on ground..lol
Old 03-30-2008, 09:12 PM   #817
you can put the bolt in the very top hole with a washer and torque em down and they should last for a long time
Old 03-30-2008, 11:50 PM   #818
MikaR's Avatar
After bolting the adjustable wing mounts I have drilled an extra hole each side and screwed in a pair of extra screws with nylocks to lock the mounts so the holes won't strip on a hard landing...
Old 04-01-2008, 04:59 PM   #819
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Guys do you recommend running the aluminum or CF ackerman plate on the Matrix Buggy ?
thanks,
Pato Concha
Southamerica
Tabushi is offline   Reply With Quote
Old 04-01-2008, 08:36 PM   #820
pato if you can run genes plate there awesome the cf will snap where it bolts down on the elbows
Old 04-02-2008, 01:29 PM   #821
Tabushi's Avatar
Old 04-04-2008, 11:57 AM   #822
Send a message via AIM to JustinD
Does the King Headz engine mount for the 777 fit the Cen buggy ?
EB MODS
Mugen MBX6 -EB MOD OS V-Spec / EB MODS FUEL
JustinD is offline   Reply With Quote
Old 04-05-2008, 10:59 PM   #823
Tabushi's Avatar
Well, finally finished just 1 1/2 weeks before the southamerican championship so im praying to get a decent result lol !! ...
- CEN Matrix FRE
- Go Tech 7 Ports engines
- Go Tech FEMCA 0801 pipe
- VP PRO Tyres
- Hitec 985 on steering and 645 on gas/break (still waiting for my ACE's)
- Protek Lipo 2.000mah + Protek 6.2v regulator
- M2C Racing 4 Shoe Setup
- Spektrum PRO
Wish me luck guys !!
Patricio "PATO" Concha
E-Mail : pato_concha@yahoo.com
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Old 04-06-2008, 07:24 AM   #824
Trader Rating: 26 (100%+)
you might want to seal the edges of your shock towers with CA to help prevent cracking,
bobf24 is offline   Reply With Quote
Old 04-06-2008, 11:47 AM   #825
Tabushi's Avatar
Seal them ?, which product ?
thanks,
CEN MATRIX FRE helivaguy Nitro Off-Road 4 08-27-2008 05:52 PM
RB 12 Matrix Matt Russell Australia For Sale/Trade 2 02-11-2008 04:31 PM
Cen Matrix dieseldog20 R/C Items: Wanted to Buy 0 02-06-2008 05:31 PM
Matrix and Matrix TR Factory Race Edition Kits SmoothB R/C Items: For Sale/Trade 4 05-31-2007 05:36 PM
Dye matrix 5 and DYE matrix 4 w/ tanks and halos for sale yuk17bandit Other Items: For Sale/Trade or Wanted to Buy 0 11-07-2006 10:49 AM
