Old 03-24-2008, 11:00 AM   #781
Send a message via AIM to JustinD
My setup is Andrews setup nothing is broken the car is brand new and everything was built right but I doesn't make me feel bad about the car cause it drives awesome.
EB MODS
Mugen MBX6 -EB MOD OS V-Spec / EB MODS FUEL
JustinD is offline   Reply With Quote
Old 03-24-2008, 11:40 AM   #782
Mcran's Avatar
We have never had a drive shaft on the buggy pop out either. Weíve been running the buggy now for a year. We usually run - 2 degrees of negative camber and 1 or 2 degrees of tow-out on the front.
We did have one pop out on the rear of the TR but since we have been running -3 degrees of camber on the rear and havenít had it happen again.
I donít know if it would work but you could try using the TR outdrives on the front. They are 2-3mm longer so the drive shaft would go up in them further. Let us know if you figure out the problem.
Team Associated, LRP, Reedy, Hobbico - www.hobbico.com,
JConcepts - www.JConcepts.net, Futaba - www.futaba-rc.com,
OS Engines - www.osengines.com, Kal-Gard - www.Kalgard.com,
Murnan Modified Motors - www.Murnanmodified.com
Mcran is offline   Reply With Quote
Old 03-24-2008, 11:44 AM   #783
MikaR's Avatar
I think I have experienced that, too, few times and nothing wasn't really that worn out. Putting some more negative camber did help, but I didn't find it a very nice way to solve the issue cause I had to use more camber than I would have really wanted to. This is not actually very surprising because if you put the A-arms in maximum intravel position (suspension compressed) the CVD pin comes out from the diff cup slightly. At least in my Matrix. There are universals around that are slightly longer that fit and you can try out if this becomes a constant issue. For me it wasn't, however, and I was able to finish all my races with the stock parts. It happened on training sessions on hard landings or something I guess.
I don't think the TR outdrives fit, they are too long to turn or something.
MikaR is offline   Reply With Quote
Old 03-24-2008, 12:55 PM   #784
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
anyone confirm if mugen mbx5 shock springs (regular, and R type) work on the Matrix shock bodies? Also, where does the stock cen blues fall in relationship to mugen shock springs?
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 03-24-2008, 01:05 PM   #785
slaytanic's Avatar
Trader Rating: 20 (95%+)
They work just fine. I did not like the reds though if thats what you are thinking. They were too long and I could not get the ride height correct no matter what I did. They are nice for bashing though.
slaytanic is offline   Reply With Quote
Old 03-24-2008, 01:47 PM   #786
Tech Legend
Cain's Avatar
Right now I got a set of mugen grey's, and a set of mugen whites.
Depending on the rating of the stock matrix springs, I will save one set and let the other go.
Old 03-24-2008, 01:55 PM   #787
DPowers's Avatar
Trader Rating: 79 (100%+)
yes i do believe the springs will work.
DPowers is offline   Reply With Quote
Old 03-24-2008, 03:14 PM   #788
The very 1st RTR's had shorter outdrives, but that problem was fixed 2 years ago. I can't help with out seeing pictures. Right now I even have Mugen CVD's on in the rear which are even shorter then CEN CVD's with no issues.
VP-Pro USA - www.raceVPpro.com
Agama USA - www.AgamaUSA.com
Maxy's Fuel - www.Maxysfuel.com
Machine's R/C H is offline   Reply With Quote
Old 03-25-2008, 07:11 AM   #789
MikaR's Avatar
OK, I replaced my front CVDs last summer, don't know which version they are. Can take a photo when have a chance.
Old 03-25-2008, 08:17 PM   #790
i highly doubt that you got shorter driveshafts this last summer i think something is setup wrong in your car cause i have never seen heard or expeirenced this problem
please post pics so we can try and help ya out
go really fast and turn left....
Robert.Hull is offline   Reply With Quote
Old 03-25-2008, 08:21 PM   #791
Andrew is at the Factory in Taiwan now checking into it I will keep yall updated.
EB MODS
Old 03-25-2008, 09:05 PM   #792
hes there to discuss the final pieces of the re-matrix
and last weekend he was at a race in tailand witch he WON in buggy and truggy
Old 03-25-2008, 10:07 PM   #793
He is also discussing the driveshaft problem and checking into it Ive been talking to hi,.
EB MODS
Old 03-26-2008, 01:46 AM   #794
MikaR's Avatar
Naah..it's not that big issue. I just wanted to say it has happened to me too, because some of the guys here were talking about it. I have shorter KMW shock bodies (designed by Gene) and this may be part of the issue due to increased intravel though Gene said it hasn't ever happened him. Check out your driveshafts the front suspension fully compressed, if your driveshafts stay in the cups all the way (including pins) then you won't have a problem - ever. Mine came out (the pins, not the axle itself) slightly and in the summer heat it is possible that arms flex a bit in a hard landing in a high jump so the shaft can pop off, usually the drive cup is damaged slightly at the same time. I doubt it will ever happen in good landings on smaller jumps.
Old 03-26-2008, 06:52 AM   #795
Default CEN Racing TQ's and wins the Tialand Cup!!!!
This just in!!!
Andrew Smolnik TQ's and wins the Tialand Cup in 1/8 Buggy and 1/8 Truggy - for a perfect weekend.
CEN MATRIX FRE helivaguy Nitro Off-Road 4 08-27-2008 05:52 PM
RB 12 Matrix Matt Russell Australia For Sale/Trade 2 02-11-2008 04:31 PM
Cen Matrix dieseldog20 R/C Items: Wanted to Buy 0 02-06-2008 05:31 PM
Matrix and Matrix TR Factory Race Edition Kits SmoothB R/C Items: For Sale/Trade 4 05-31-2007 05:36 PM
Dye matrix 5 and DYE matrix 4 w/ tanks and halos for sale yuk17bandit Other Items: For Sale/Trade or Wanted to Buy 0 11-07-2006 10:49 AM
