Old 02-26-2008, 03:34 AM   #676
Congrats Pato, good luck this year
nayslayer is offline   Reply With Quote
Old 02-26-2008, 05:06 AM   #677
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Just saw it on buggy-sport :
cya !
Patricio "PATO" Concha
E-Mail : pato_concha@yahoo.com
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 02-26-2008, 05:26 AM   #678
Paradoxmaker's Avatar
cya !
Dang, another great driver gone due to Ofnas' (hoboa/hongnor) inability to either sign or keep some of it's best racers and supporters....
Good luck Pato
Paradoxmaker is offline   Reply With Quote
Old 02-26-2008, 06:13 PM   #679
Default Center brake drive cups
Is there any stronger replacement for the center drive cups. Mine have a good notch in them, where as the front and rear seem fine. Anyone know of any other that may work in place of these?
Old 02-26-2008, 06:21 PM   #680
TripleX-JT's Avatar
Send a message via MSN to TripleX-JT
Welcome to the Elite Team Pato!!!
Josh Thompson
CEN Racing - GO Tech Engines - UPgrade RC - Northern Hobbies - Khaos Designs
TripleX-JT is offline   Reply With Quote
Old 02-27-2008, 04:14 AM   #681
MikaR's Avatar
yes, there is new version available with better hardening, equal to those you currently have front and rear. They are marked on the packade with an acronym which I don't remember just know. Something with a "d" or "p".
MikaR is offline   Reply With Quote
Old 02-27-2008, 07:12 AM   #682
yea just order a new set and they should be the new ones
(they last a very long time)
go really fast and turn left....
Robert.Hull is offline   Reply With Quote
Old 02-28-2008, 06:41 PM   #683
thanks again robert, back to the leaky diff. i took apart the diffs again, and noticed it was leaking from the shims, i just removed them and all seems well.. time will tell, but so far alot better. Perhaps i had the screws too tight and cause the shim to bend slightly? eh who knows
Old 02-28-2008, 07:46 PM   #684
you should have 1 shim in there
is it leaking outside of the diff or is there just oil on the shim when you break it open?
Old 02-29-2008, 03:46 AM   #685
the oil is outside of diff, when i crack the diff open, the gasket is clean, but the diff case side of shim, there is a small area that is wet, from where i guess the oil is escaping
Old 02-29-2008, 07:16 AM   #686
of if you can clearly tell its one little area then your shim is most likely bent like you said i suggest just getting a new shim
you do have a gasket on each side of the diff right?
Old 02-29-2008, 08:43 AM   #687
yeah, gasket on both sides, i'm convinced that the shims are the issue. The diff seems very smooth without the shim, although, i do have a few spares, Would it hurt to run without them? I rebuilt all diffs with the new plastic diff case and new pins.
Old 02-29-2008, 04:54 PM   #688
im not sure if it will hurt to run with out cause you just shim the diff till its smooth and in good operation and you said its smooth so yea give it a try and see what happens
Old 02-29-2008, 08:59 PM   #689
Tabushi's Avatar
Old 03-02-2008, 12:39 PM   #690
MikaR's Avatar
Hi, my Matrix has been on diet.. it's running weight is now 7.25 pounds (3290g), with BBF diffs slightly higher 3330g. This is ready to run without gas in tank. I think it's pretty light now.
CEN MATRIX FRE helivaguy Nitro Off-Road 4 08-27-2008 05:52 PM
RB 12 Matrix Matt Russell Australia For Sale/Trade 2 02-11-2008 04:31 PM
Cen Matrix dieseldog20 R/C Items: Wanted to Buy 0 02-06-2008 05:31 PM
Matrix and Matrix TR Factory Race Edition Kits SmoothB R/C Items: For Sale/Trade 4 05-31-2007 05:36 PM
Dye matrix 5 and DYE matrix 4 w/ tanks and halos for sale yuk17bandit Other Items: For Sale/Trade or Wanted to Buy 0 11-07-2006 10:49 AM
