Old 01-08-2008, 07:54 PM   #631
tron 101-- i understand completly whats going on and it make me mad as well but most those guys are just guessing next time they say something ask them......have you driven this car,owned this car i can guarantee you 99% of them will say no there just going by what they heard CEN has a few buggies that qualified for the worlds this year along with lots of other wins and great placing at the truck nats last year CEN was the only monster truck that did not break the revo and lsts did Andy bump from the C-main to the B-main to yup you guessed it the A-main and finshed a very respectable 2nd place with out any problems through all those mains
i hear people at tracks i go to sometimes saying the same thing i just let it go and let the result speak for it self
just do good and show them its a great buggy whitch it is as well as the truggy dont let them get to you its very durable and handles extremly well
but most all the time there just throwing words outta their mouth that they heard from someone else and have never expeirenced CEN
go really fast and turn left....
Robert.Hull is offline   Reply With Quote
Old 01-09-2008, 10:53 AM   #632
Hi,
I just got a Matrix Buggy FRE edition.
I' new to this and would like to know if I need any option parts and
I need help with a setup for a bumpy, low traction track.
Frode
Tigergutt is offline   Reply With Quote
Old 01-09-2008, 06:40 PM   #633
as far as upgrades go these are the only two you should do right off the bat....
http://www.headrushhobbies.com/estor...pgrade%20Parts
i would try 40wt shock oil in front with #2 pistons and 30 in the rear with #2 pistons
diffs they should be crosspins so starting from the front 7/10/4 or 5
if you have any other questions just ask
Old 01-11-2008, 10:23 PM   #634
Tron 101's Avatar
Trader Rating: 23 (96%+)
Default !!
I want some threaded shocks on ,my buggy. Has anyone done this mod if so what company has the same size shocks, so I don't limit my travel or bottom out. Thanks
PEACE.
Tron 101 is offline   Reply With Quote
Old 01-12-2008, 06:46 AM   #635
CEN didnt do threaded shocks cause through long mains the nut will loosen up and set the car off
you can rebulid your shocks or use the preloads the threaded shocks are the same and using pre loads except they are not consistant
Old 01-21-2008, 04:32 AM   #636
MikaR's Avatar
Originally Posted by Tron 101 View Post
Is the type "S" chassis a direct add on? it is after all shorter, so do I have to get shorter CVD's? PEACE CEN!!
Hi there Tron 101, no you don't need any extra parts, unlike Kyosho it is a direct fit. You can switch between S and L chassis without changing any other parts. However, you may need to readjust your body slightly and body post holes naturally.
MikaR is offline   Reply With Quote
Old 01-29-2008, 05:07 PM   #637
Trader Rating: 19 (100%+)
I've got a new matrix fre pro kit for sell, 100 less than amain, it's been assembled, never run includes body, wheels tires. picked it up from a guy a the track, has lsd diffs, I put aluminum diff casings cuz the plastic ones leaked. PM me if interested. 250 or trade for a nice 28 Pooldoc
pooldoc is offline   Reply With Quote
Old 02-07-2008, 05:52 PM   #638
Default Front UPPER SUSPENSION ARM
I thought i remember seeing these in the red aluminum set for release. Did i bump my head last spring, or what? It was a replacement for part MX012 . If not, is there another upgrade for this area? Thanks
nayslayer is offline   Reply With Quote
Old 02-07-2008, 08:15 PM   #639
your talking about the metal threaded piece for the upper supension arms???
if so i think you got it confused with the wing mount post those came out a while ago released in red
gene makes a set of blues ones....
if im wrong please let me know so i can hopefully get you the right info
Old 02-08-2008, 05:20 AM   #640
your right robert. But it thought i saw that suspension piece on the upgrade sheet last year, for the upper front suspension arm
Old 02-08-2008, 06:58 AM   #641
no not that i know of and if it is its not out
Old 02-08-2008, 08:11 AM   #642
thanks robert
Old 02-11-2008, 06:45 PM   #643
will the new cen cross pins fit into the alumint diff housing like Gene's does? One of his wasn't machined so well, and has failed. Do i need to get a diffrent housing for this, or can i just use the aluminum that works with his custom cross pins
Old 02-11-2008, 06:58 PM   #644
is it to long
if so you can shave it with a grinder
you best bet would be to get the new cen housings and pins all the way through
Old 02-11-2008, 07:17 PM   #645
the new cen pins/diff case combo is better than gene's?
CEN MATRIX FRE helivaguy Nitro Off-Road 4 08-27-2008 05:52 PM
RB 12 Matrix Matt Russell Australia For Sale/Trade 2 02-11-2008 04:31 PM
Cen Matrix dieseldog20 R/C Items: Wanted to Buy 0 02-06-2008 05:31 PM
Matrix and Matrix TR Factory Race Edition Kits SmoothB R/C Items: For Sale/Trade 4 05-31-2007 05:36 PM
Dye matrix 5 and DYE matrix 4 w/ tanks and halos for sale yuk17bandit Other Items: For Sale/Trade or Wanted to Buy 0 11-07-2006 10:49 AM
