Old 06-22-2007, 01:50 PM   #481
They are case hard (black coating).
The Machine's R/C Hobbies pins are hardened all the way through now.
Machine's R/C H is offline   Reply With Quote
Old 06-22-2007, 05:35 PM   #482
Moderator
pc9840's Avatar
Send a message via ICQ to pc9840 Send a message via AIM to pc9840 Send a message via Yahoo to pc9840
Default Matrix
Mines just about broken in... As soon as thats done I'm going to take it to the track to tune it and play a little. So far so good though.
Jesse@pc9840.com <><
"The minimum wouldn't be the minimum if the minimum wasn't good enough"
pc9840 is offline   Reply With Quote
Old 06-22-2007, 07:56 PM   #483
Moderator
pc9840's Avatar
Default Clutch Shoes
For those of you that are using the stock clutch, what clutch shoes are you using?
Old 06-22-2007, 09:45 PM   #484
Alum. shoes and mugen 1.1 springs
Kyosho / Team Orion / AKA / JTP / Sharkbait Designworks / RC Tracks of Las Vegas
Chris Jarosz is offline   Reply With Quote
Old 06-23-2007, 12:42 PM   #485
Moderator
pc9840's Avatar
Default Clutch
Is it normal for the clutch to get tighter? I have broken in my engine and was tuning it today and noticed the clutch got tighter. The car used to roll really freely without the clutch catching at all. Now I can feel the clutch catching when I roll the car.
Is this normal or do I need to adjust the clutch? How often should I have to adjust the clutch? Should I wait to upgrade untill this one is worn out or should I just upgrade now to alum. shoes and avoid any possible future headaches with the stock shoes?
Old 06-25-2007, 07:23 AM   #486
Check the following:
broken spring
loose nut
bad bearings
The clutch shoes should not touch the bell until engaged.
VP-Pro USA - www.raceVPpro.com
Agama USA - www.AgamaUSA.com
Maxy's Fuel - www.Maxysfuel.com
Old 06-25-2007, 08:13 AM   #487
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
I know my springs the last time I built them were looking pretty rough, especially the 1.0mm ones.
I am thinking of trying 1.1mm all around, with the 2 carbon shoe and 1 aluminum shoe setup, and also putting new bearings in.
Just haven't had the time yet to sit down and work on it. Hope to Thursday and Friday.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 06-28-2007, 09:31 PM   #488
outtafocus's Avatar
www.rcdepot.ca-Hobbywing-Tekno-TLR-Brass Knuckle Brush Worx
outtafocus is offline   Reply With Quote
Old 07-12-2007, 10:04 AM   #489
Congrats to Chris Systma taking down 1st place in the R/C Driver Race
of Champions in the Buggy A Main.
http://www.wolcotthobby.com/e107_plu...2FBruggy-A.jpg
http://www.wolcotthobby.com/e107_plu...s/Bruggy-A.jpg
Old 07-12-2007, 01:22 PM   #490
Default Strong/light weight front upper tie rods
I have new front upper alum turnbuckles for the Matrix TR Arena for sale now.
They are available on ebay. The new hardened cross pins are listed also.
Front Upper CNC Turnbuckles
Hardened Cross Pins
Old 07-12-2007, 01:25 PM   #491
Other CEN Matrix hop-up parts will be coming soon from Machine's R/C Hobbies Racing Products.
http://www.machinesrchobbies.com
Old 07-13-2007, 03:30 AM   #492
jfc_tech's Avatar
Send a message via Yahoo to jfc_tech
We can't wait.
If you are in front of me, That's because I let you!
jfc_tech is offline   Reply With Quote
Old 07-17-2007, 01:02 PM   #493
New Alum CNC Front upper turnbuckles
Old 07-23-2007, 10:35 AM   #494
Tech Legend
Cain's Avatar
Hey guys.
I have a handling question that I need some advice on.
To start with, I am running Genes setup other than having Trinity 32.5W up front and Trinity 30W Rear, and 3K-3K-3K diff setup using the stock diffs.
This works well, and the only issue I have is that when powering out of a turn midway threw, the rear wants to kick out on me and get squirrly.
Other than that, the vehicle is pretty much on rails around the track.
I was thinking of going with 27.5 - 25W in the rear.
Any thoughts or recommends? Open to any diff changes as well since I am going to give it a clean through to be ready for my race this weekend.
surface is dry with a light dust on top. Running a crimefighter style tire, similar to XTR compound. but others running the same compound and tire type are doing fine so I think its a setup issue. I'll have a set of k2s coming in I can try as well.
Thanks!
Old 07-23-2007, 03:28 PM   #495
Try cross pins in the rear or grease. With 3,000 in a LSD diff, your rear end will always be loose and come around on you.
CEN MATRIX FRE helivaguy Nitro Off-Road 4 08-27-2008 05:52 PM
RB 12 Matrix Matt Russell Australia For Sale/Trade 2 02-11-2008 04:31 PM
Cen Matrix dieseldog20 R/C Items: Wanted to Buy 0 02-06-2008 05:31 PM
Matrix and Matrix TR Factory Race Edition Kits SmoothB R/C Items: For Sale/Trade 4 05-31-2007 05:36 PM
Dye matrix 5 and DYE matrix 4 w/ tanks and halos for sale yuk17bandit Other Items: For Sale/Trade or Wanted to Buy 0 11-07-2006 10:49 AM
