Old 06-18-2007, 08:51 AM   #466
Trader Rating: 26 (100%+)
its fine to adjust it during break in, you probally just need to lean the bottom end in a bit, or your idle might be too low,
for having to blip the throttle to get it to fire, thats normal, and I dont think there is any adjustment that is really going to stop that, its just because its cold and you need to get some heat into it before its going to run properly, the same idea as you have to wait for the engine to warm up before you can tune it, they run totally different when cold vs up to temp,
for the clutch, make sure you didn't lock the diff up when you tightened the bolt holding the clutch on, you have to be able to tighten the bolt in the crank all the way down, and still have a small amount of front to back play in the CB, otherwise the bearings dont spin free and it locks up,
bobf24 is offline   Reply With Quote
Old 06-18-2007, 10:08 AM   #467
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
So, if the clutch bell doesn't have alittle back and forth movement to it, that could be the problem?
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 06-18-2007, 10:41 AM   #468
yes, did you try and spin the clutch bell after bolting it down? it should spin really free, if the gap is too small, when all the metals expand the gap can change and that could be why it would lock up after you are using it,
also make sure any shims you are using only touch the inside race of the bearing, if they are touching both the inner and outter races, it wont let the bearing work properly either,
Old 06-18-2007, 10:54 AM   #469
Tech Legend
Cain's Avatar
Thanks again.
i recall that I didn't need any shims between the screw that holds the whole clutch assembly on. Its basically setup the same as how the manual says, but there was no side to side play. After letting it cool down however it is still locked up so when I pull the engine I will take a look and see what the issue is.
It did however spin free prior to my run installed.
Old 06-18-2007, 01:04 PM   #470
just to clarify, I mean play front to back, along the axis of the crank, when you said side to side I just wanted to make sure we were talking about the same thing,
its not necearily whats wrong, but its an easy place to start looking, just loosen the screw off, and see if the clutch free's up, if it still bound up then something else is the problem,
Old 06-18-2007, 01:25 PM   #471
Tech Legend
Cain's Avatar
I got ya, thats what I meant too.
Old 06-18-2007, 09:18 PM   #472
Originally Posted by Cain View Post
Thanks again.
Sounds like your flywheel nut came loose, backed out and has locked your clutch bell. A little lock tite fixes that.
Tebo is offline   Reply With Quote
Old 06-19-2007, 10:46 AM   #473
Tech Legend
Cain's Avatar
unfortunately if that is the case then it is not locking up as I have been putting loctite on it. I think the collet is part of the issue. I may just have to order another one like someone else recommended on here.
Old 06-19-2007, 04:20 PM   #474
outtafocus's Avatar
I just finished the assembly of my Matrix buggy kit.
The build went very smoothly and found the instructions to be very clear.
I did experience a minor problem with one of the front shock bodies. The space at the bottom of the body which holds the 2 o-rings and the white spacer was machined off center, so I was unable to thread on the bottom cap with a shock shaft installed. Luckily I was able to use a body from my spare TR kit.
I also found the shock mounting posts to be very difficult to thread in the screws. I feel a 3mm tap would be a nice thing to have to clean up the threads a little.
As you can tell from the pics I mounted up my spare set of red aluminum shock towers on my buggy.
www.rcdepot.ca-Hobbywing-Tekno-TLR-Brass Knuckle Brush Worx
outtafocus is offline   Reply With Quote
Old 06-22-2007, 08:57 AM   #475
Tech Legend
Cain's Avatar
So how is everyone doing with there matrix's?
Old 06-22-2007, 10:02 AM   #476
kamlooper's Avatar
Tearing mine down for a going over, getting ready for round 2 of the CORCS series up here in the great white north. Im sure hoping the cross pins show up today.
kamlooper is offline   Reply With Quote
Old 06-22-2007, 10:25 AM   #477
Tech Legend
Cain's Avatar
I am going to try the CEN crosspin conversion when its available.
Hope to get to work on my buggy tomorrow or the sunday to work out this clutch issue.
Old 06-22-2007, 11:23 AM   #478
I have the new CEN cross pins and cases in stock (MX212,MX213). I also have my hardened cross pin convertion kits in stock. The CEN kit for 3 diffs are $30 shipped, mine are $40 shipped and will work with all 3 cases (MX036, MXS39, MX212) and last much longer.
VP-Pro USA - www.raceVPpro.com
Agama USA - www.AgamaUSA.com
Maxy's Fuel - www.Maxysfuel.com
Machine's R/C H is offline   Reply With Quote
Old 06-22-2007, 12:29 PM   #479
kamlooper's Avatar
Theyre here! Ordered them 1 week ago from cen...thats quick service! Thanks Ken.
Old 06-22-2007, 01:29 PM   #480
any idea where the CEN pins rank in hardness?
CEN MATRIX FRE helivaguy Nitro Off-Road 4 08-27-2008 05:52 PM
RB 12 Matrix Matt Russell Australia For Sale/Trade 2 02-11-2008 04:31 PM
Cen Matrix dieseldog20 R/C Items: Wanted to Buy 0 02-06-2008 05:31 PM
Matrix and Matrix TR Factory Race Edition Kits SmoothB R/C Items: For Sale/Trade 4 05-31-2007 05:36 PM
Dye matrix 5 and DYE matrix 4 w/ tanks and halos for sale yuk17bandit Other Items: For Sale/Trade or Wanted to Buy 0 11-07-2006 10:49 AM
