Old 04-24-2007, 08:03 AM   #301
With the stock diffs, try 80wt gear oil/3,000/grease
Or just get the cross pins and use 5,000/5,000/2,000
For shocks, use #2 pistons in the front with CEN 30wt and #3 pistons in the rear with Cen 30wt - that is the best starting point.
VP-Pro USA - www.raceVPpro.com
Agama USA - www.AgamaUSA.com
Maxy's Fuel - www.Maxysfuel.com
Machine's R/C H is offline   Reply With Quote
Old 04-24-2007, 05:02 PM   #302
Trader Rating: 14 (100%+)
hey gene, what type of springs were you using on your buggy at the AIC. they were light blue. also thanks for the KMW shocks, they worked out great.
thanks james L.
jlo8864 is offline   Reply With Quote
Old 04-24-2007, 09:20 PM   #303
kamlooper's Avatar
I need to order a main gear for my matrix, not sure which one though. I see 2 in the parts list;
GS006
MSX24
Are they the same or different teeth count?
kamlooper is offline   Reply With Quote
Old 04-24-2007, 09:28 PM   #304
Trader Rating: 26 (96%+)
What parts other then the standard diff gears does this buggy need?
party_wagon is offline   Reply With Quote
Old 04-24-2007, 09:34 PM   #305
kamlooper's Avatar
Actually I need the spur gear, not diff gear. (but was going to get crosspin set)
I was going to also order,
a clutch bell, bumper, shock booties, preload spacers, shock cap inserts.
More to add.
Do you have parts?
Old 04-24-2007, 09:51 PM   #306
you guys can check out headrushhobbies.com for all cen parts
go really fast and turn left....
Robert.Hull is offline   Reply With Quote
Old 04-25-2007, 05:33 AM   #307
Trader Rating: 26 (100%+)
you want the MXS24, its the steel 46T spur, I think the other number is the old cast 46T version, which you really dont want, I stripped basically every tooth off the cast version within a few races, and I've got an entire season + on the steel one and it still looks like new,
bobf24 is offline   Reply With Quote
Old 04-25-2007, 06:46 AM   #308
More to add.
Do you have parts?
Just get Mugen preload spacers instead. They fit fine and give you a wider range of adjustment.
Kyosho / Team Orion / AKA / JTP / Sharkbait Designworks / RC Tracks of Las Vegas
Chris Jarosz is offline   Reply With Quote
Old 04-25-2007, 07:01 AM   #309
actually gs006 is a genesis part and might be the spur gear from it
so yea mxs24 would be your gear
Old 04-25-2007, 07:11 AM   #310
actually its simply the cast 46T version, it may be used in the genssis, I dont know anything about that truck, but it is for sure listed in the replacement parts for the RTR buggy, have a look for yourself, http://cenracing.com/cars/matrix/replacement.html
Old 04-25-2007, 09:16 AM   #311
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
You guys at Headrushhobbies, if I find another site online that has a cheaper price than you, do you guys beat the price?
No LHS here so I do most of my shopping online.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Cain is online now   Reply With Quote
Old 04-25-2007, 10:15 AM   #312
Tech Legend
Cain's Avatar
I am not sure if this was already asked, but what was is the stock diff configuration that the matrix RTR comes with diff fluid wise? I like how it feels out of the box, may just up the shock oil but I want to give it a good clean out and know what its configuration was first before doing this.
I am thinking its either 3K-3K-3K or 5K-5K-5K .
I am also going to try using just 1 aluminum clutch shoe and the two carbon ones. Do you need to shim behind those carbon shoes like the aluminum ones?
Also, how do you know when you shot a set of shoes?
Old 04-25-2007, 10:22 AM   #313
I was using the mugen Blue. They are softer then the Cen blues.
Old 04-25-2007, 12:55 PM   #314
aluminum shoes will get a bunch of build up on the edges and over the spring, also on the tip, if you check them regularly, you can file them, and get alot more life out of them, you can usually file them a few times before they are worn down too much, usually they are completely done when your clutch springs starts dragging the clutch bell, but one thing to consider, the more material you wear off the shoes, its going to change the way the clutch reacts because the weight is going to change, its probally not a huge difference thoguh,
for composite shoes, you can probally use them till just before the spring starts to drag, since they wegiht so much less anyway, the weight differecne for wear isn't going to make as much difference, just make sure your clutch isn't slipping and melting the shoes, if its slipping it will build up a lot of heat,
Old 04-25-2007, 03:49 PM   #315
Tech Legend
Cain's Avatar
thanks for the info, very informative.
Another question, I don't think I fully understand the differences between using the 1.1mm spring versus a 1.0mm spring for the clutch shoes. Can someone give me some insight into this?
CEN MATRIX FRE helivaguy Nitro Off-Road 4 08-27-2008 05:52 PM
RB 12 Matrix Matt Russell Australia For Sale/Trade 2 02-11-2008 04:31 PM
Cen Matrix dieseldog20 R/C Items: Wanted to Buy 0 02-06-2008 05:31 PM
Matrix and Matrix TR Factory Race Edition Kits SmoothB R/C Items: For Sale/Trade 4 05-31-2007 05:36 PM
Dye matrix 5 and DYE matrix 4 w/ tanks and halos for sale yuk17bandit Other Items: For Sale/Trade or Wanted to Buy 0 11-07-2006 10:49 AM
