Old 03-05-2007, 02:51 PM   #151
Originally Posted by Machine's R/C H
Just use thick grease unless you get the Cross Pin conversion Kits. Then you can use silicone oil such as 5,000/5,000/2,000.
machinesrchobbies@hotmail.com
Pardon the stupidity, but are we talking something we can pick up at walmart or is it RC Specific?
TxCZShooter is offline   Reply With Quote
Old 03-05-2007, 02:58 PM   #152
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
I heard that the 3-3-3 setup was a good starting point.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 03-05-2007, 06:18 PM   #153
t4usee's Avatar
Kinda looks just like axel grease. The type ypu put in the palm of your hand to pack a bearing with.
I wonder how the red fluid for Kyosho would work.
t4usee is offline   Reply With Quote
Old 03-05-2007, 06:36 PM   #154
Well that's easy enough. I just acquire 2 complete diffs in a parts lot 1 alum,
1 plastic and gears enough to create a 3rd center diff. But the one I took
out of the car seemed to be lacking on lube.
Do these things have a issue with leaking? If so is there a fix?
Old 03-06-2007, 04:07 AM   #155
Default diffs
I am running the K diffs and I really like 5,5,2.
brian kadow is offline   Reply With Quote
Old 03-06-2007, 10:01 AM   #156
Any high temp grease will work. Kyosho LSD oil will work. And 80 WT diff gear oil will work found at automotive store.
But I would not race the buggy with out my cross pin conversion kit to make the diff standard style with silicone oil.
Use RTV sealant on the gaskests to keep them from leaking or get the alum diff cases that come with the TR Arena.
VP-Pro USA - www.raceVPpro.com
Agama USA - www.AgamaUSA.com
Maxy's Fuel - www.Maxysfuel.com
Machine's R/C H is offline   Reply With Quote
Old 03-06-2007, 10:35 AM   #157
And how much is the pin conversion kit?
Old 03-06-2007, 11:32 AM   #158
$39.99
Old 03-06-2007, 11:50 AM   #159
Okay. I'll stick with stock for now. Thanks for the info.
Old 03-06-2007, 12:53 PM   #160
you might wanna rethink on what you just said "ill stick wth stock for now"
if you get those pins you will flip out on the difference of the ride........but its your choice
go really fast and turn left....
Robert.Hull is offline   Reply With Quote
Old 03-06-2007, 01:07 PM   #161
At this point, I won't know the difference because I haven't actually had the chance to drive it yet.
First time we got it running, didn't check the screws on motor/mount and stripped main gear.
Had to wait for the replacement. So just to get it going for now, it will be fine. Are any of the diffs
from other brands interchangeable. Like if I had a couple spare OFNA diffs hanging around?
Old 03-06-2007, 01:15 PM   #162
Ofna/Kyosho will fit. Just bolt on the CEN ring gear.
Old 03-06-2007, 01:20 PM   #163
I am now including my cross pin conversion kit with all Matrix Pro FRE kits. E-mail for a great price and put "RCTECH" in the subject.
Old 03-06-2007, 03:03 PM   #164
Duneaddict's Avatar
Gene,
Do you know what combinations you get with the spacers on the eck-tec block?
I have no instructions and did not see anything on the website.
Duneaddict is offline   Reply With Quote
Old 03-06-2007, 03:09 PM   #165
No idea. I just measured it compared to the stock blocks but they are not exact.
CEN MATRIX FRE helivaguy Nitro Off-Road 4 08-27-2008 05:52 PM
RB 12 Matrix Matt Russell Australia For Sale/Trade 2 02-11-2008 04:31 PM
Cen Matrix dieseldog20 R/C Items: Wanted to Buy 0 02-06-2008 05:31 PM
Matrix and Matrix TR Factory Race Edition Kits SmoothB R/C Items: For Sale/Trade 4 05-31-2007 05:36 PM
Dye matrix 5 and DYE matrix 4 w/ tanks and halos for sale yuk17bandit Other Items: For Sale/Trade or Wanted to Buy 0 11-07-2006 10:49 AM
