Balooning Tyres Question
#16
The foam dosn't cause the tire to balloon the rubber tire balloons.
You don't want a hard piece of tape between the tire and the foam. The inside carcass of a tire has grooves/patterns that actually dig into the foam to stabilize it. This is what is happening when you break in a tire, it is seating the inside of the carcass to the foam.
#17
VP Pro had some "belted" tyres a while back, not made anymore but some are still available in Australia. But balloning tyres aren't that bad as the diameter of the tyre grows it helps with a higher top speed, same way as top fuel dragsters get huge speeds.
#18
try useing a hole puncher on all 4 tires and that will allow the excess air to bleed out.. racers at our track do this and have been for a while.. esp the serious ones.. and it has done well..
aka has a hole puncher but other wise just go to your local hardware store and puck one up..
#19
On the ground, I don't care for it much (ballooning) and would have started trying to do something about it if it weren't for how much control it gives me in the air.
I do a lot of jumping and I've noticed the tire sets I have that don't balloon much aren't as good for having throttle control in the air.
The tire sets that balloon up real good make for my best jumping, especially for those mean nose dives.
#20
Any tire that I make up I put Gorilla tape on em . Keeps ballooning to a minimum .
Originally just used any brand duck tape but didn't hold up . 1/2" overlap with gorilla
keeps together , and be mindful of rotation for the overlap that you keep it same direction
#21
I would say thicken centre diff aswell. However Kyosho's are probably the worst culprit for ballooning the fronts as anything thicker than 5 in the centre doesn't suit the handling characteristics of the car. I have tried running a bead of glue down the centre of the tyre inside of tire rib, but hasn't really worked. I just find if I run soft or harder it's not too much of an issue. Supersofts however kill it and I usually end up destroying my body as they balloon so much on the front.
#22
Here's a pic I found of one of mine with the tires ballooning pretty consistently.
I'm not even sure if this is any kind of problem.
In the dirt is fine with me but I had a set of Proline street tires that did this and wore the center down after only a few runs that got so bad so quick that one of them tore down the middle.
But with this particular set shown in the pic, I do all my jumping with ALL my cars I run this set on.
They're Duratrax Lockups.
#23
Wow ozziii Your JQ and those tyres look like they have max grip and traction sorted. If I can source those VP Pro belted tyres, that will save me messing about experimenting with the 'Sikaflex' and fibre tape. My driving skill has a very long way to go, before I get near to the level of our clubs 'Ace' drivers, but my choice of tyres do suffer from rapidly loosing their tread pattern in the centre portion. Your tip is much appreciated Paul, thanks.
#25
Sent you a PM about tyres Bushman.
#26
All good mate, glad I could help.
#28
It's called diff'ing out. Center diff (or front diff or combo of front and center if in a turn) is too light or not filled enough or leaked out. These diffs are"open diffs". Power is sent to whichever wheel has the least amount of traction just like an old muscle car that doesn't have posi-traction (or the various different names given by manufacturers) will only spin one rear tire when doing a burn out. A posi-traction car will burn both. With r/c's we adjust our diffs anywhere between open and posi-traction with the thickness of the fluid. Less traction on any given tire on our cars comes from the lack of load on the each tires and the looseness of the track under each tire. Light center diff + punch it out of the hole = weight transfers off the front tires and then spin up (or diff out). The thicker the center, the less this happens.
Make a left turn and punch it + light center diff + light front diff= weight transfers off the front left and onto the back tires and front right and so the front left spins up and balloons.
It's a balance too. You can't just put 100k in your diffs and expect your car to handle right. It needs differentialing action in order to handle. Also, let off the gas!
