Glow Plugs?!
Glow Plugs?!
Hi all, need some advice on which glow plugs are best for my two cars. Both thunder tiger. EB4 and EK4. Not sure what do buy. Ive heard OS 8 are good? any thoughts and recommendations would be great.
The O.S #8 is a medium heat plug & should work well, but the O.S #7 is slightly warmer being a medium/hot plug & may make the tuning slightly easier as a warmer plug creates a slightly wider tuning window.
Best way to check is take the cooling head & burn room off the engine & try some different plugs to see how they fit, they shouldn't protrude past the threads into the burn room, they should sit level so the fuel flows evenly around the burn room.
Thanks for the replies. The EB4 has a Pro 21r engine and the EK4 has pro 70
originally had ENYA 3 plugs as standard?. still unsure whats best for both engines, will OS 8 be ok for both? James
