Old 08-06-2006, 11:31 PM   #451
motomanpat's Avatar
Well I put the front alignment plate back on tonight and it is a no go.If the front plate is off then I have plenty of contact but when it is on and the car is pushed all the way down on the wheel it just barely hits the wheel but not enough to turn over the motor.I am not sure what the deal is but I know that I will not go race until I have these few issues fixed.I know that if I flame out at a race and some pit guy(that I don`t know) is there to help me he will not be able to easily get it lined up and started.Not sure about the throttle/brake linkage either.When I was at the track and hit the brake full and let off the little slider that is on the shaft on the throttle side would stick just enough to pull the throttle out enough to make it creep forward pretty good.This to me is not acceptable because when I enter a corner I will not have effective braking therefore I will push in a corner initially.
motomanpat is offline   Reply With Quote
Old 08-06-2006, 11:34 PM   #452
motomanpat's Avatar
The throttle brake thing will probably be fixed if I can find a way to hookup a throttle return spring.Just not sure as there is no hole to hook it too.
Old 08-07-2006, 06:47 AM   #453
tex1's Avatar
Send a message via Yahoo to tex1
Thumbs up Pat....
Go get yourself a Losi Gas truck throttle return spring set. Hook it to your carb post and your opposite side motor mount screw. If your throttle servo looses power it will help pull the carb closed.
If you get your linkage aligned right it should work smooth and free. The stock linkage worked just fine on my car. 4 of us are running these cars and they are fine.
Dibs,
I'm coming to OKC! Maybe we can get a beer. I'll be driving the Orange Majestic H8 with a black wing.
TEX
www.indyrcworld.net
Indy RC World 2.0 - Garland, TX
T&T RC Cars - Plano, TX
(972) 271-4844
tex1 is offline   Reply With Quote
Old 08-07-2006, 08:02 AM   #454
Motorman007's Avatar
Trader Rating: 76 (100%+)
Cool Tex I may not run that weekend, but i will be around to talk to my old buddies like you..
how are things going down in tx? i hope well.
cya next man.
dibs
Motorman007 is online now   Reply With Quote
Old 08-07-2006, 12:24 PM   #455
nsane's Avatar
Originally Posted by motomanpat
Well guys,
I have the OFNA lightweight starter box but I had to take off the front line up plate to make it have enough contact to hit the flywheel.So my main problem is if I go race and I need a pit guy he will not be able to just put the car on the box easily and have it line up correctly.I know I could put a larger flywheel on it but I would prefer not to.Is there any other fix for this or what?
Shim the starter motor so the wheel is up higher?
As for the line up, you could get the TKO starter box plate (which will DEFINATELY require you shim the motor in the box up). I use one with my H8 and it makes it a pretty easy drop on and start.
nsane is offline   Reply With Quote
Old 08-07-2006, 03:07 PM   #456
kartmarket's Avatar
Default Thanks guys
Ok guys ive been reading this post for about 5 hours now could not decide between the jammin or hyper8 well i have to say after 5 hours of reading i think im going with the hyper 8. I want to thank all the guys for helping me make this choice ill let you know what happends when the wife finds out... Ok maybe i wont when she sees the bill
kartmarket is offline   Reply With Quote
Old 08-08-2006, 12:20 AM   #457
motomanpat's Avatar
I don`t think you can really shim it up as then the pulley would rub the top inside of the box.Now if I cut the hole bigger where the wheel comes out and then also cut the little slots higher for the belt tensioner where the wheel connects to the mounting plate then I think it would work.I just don`t really feel right doing this but that is the way that I am probably going to go.I know that I read somewhere on the ofna forum where someone had the same issue and they said get a jammin or 7 flywheel but I can`t find it now.Any ideas would be very helpful at this point!!!!!!!1
Old 08-08-2006, 04:02 AM   #458
tex1's Avatar
Red face Flywheel....
Had an issue here at the shop with a guy not being able to start his car on the OFNA box.
After looking at the situation, two things were going on.
1. The flywheels were different sizes. We had 4 OFNA flywheels and they were 2 different sizes. His was the smaller one.
2. The motor in the box was very weak. OFNA saw this and replaced it.
Funny thing was the Mugen and the Works flywheels are like this as well once we went through our stock.
He is good now.
TEX
<---- They are still not done!
www.indyrcworld.net
(972) 271-4844
Old 08-09-2006, 01:44 PM   #459
kartmarket's Avatar
Default Shop
Hey Tex any ideas where i can buy the hyper 8 they want 450$ for it at the hobby shop near my house i see alot for sale on the net. Was just trying to find a place on the net for cheaper
Old 08-09-2006, 02:56 PM   #460
LSUsportsfreak's Avatar
Here's one:
Ebay
LSUsportsfreak is offline   Reply With Quote
Old 08-09-2006, 03:04 PM   #461
Panther's Avatar
Send a message via AIM to Panther
I'll sell you one that is in great shape with Big Bore shocks for $345 shipped. Let me know if might be interested.
-Seann
Panther is offline   Reply With Quote
Old 08-09-2006, 03:14 PM   #462
Moderator
WYLDTHING's Avatar
Trader Rating: 148 (99%+)
-Seann
Again??? Dang it Seann!!!!
<>< JESUS IS MY HERO! ><>
==TEAM NOVELTY==
WYLDTHING is offline   Reply With Quote
Old 08-09-2006, 03:15 PM   #463
Moderator
WYLDTHING's Avatar
There are 3 used ones on tech talk right now......
==TEAM NOVELTY==
Old 08-09-2006, 04:25 PM   #464
kartmarket's Avatar
Default New
Im going to buy one but want it new so i know what im getting into no offence.
Old 08-09-2006, 05:10 PM   #465
Panther's Avatar
None taken,
Just trying to save you some money on a new one. This thing still has everything it came with.
-Seann
Hyper8/8.5 Dietz R/C Items: For Sale/Trade 13 12-31-2007 09:04 PM
hyper8/8.5 parts Dietz R/C Items: For Sale/Trade 1 10-23-2007 07:26 PM
hyper8 pro dwillard R/C Items: For Sale/Trade 2 08-03-2007 01:47 PM
WTB!!! Hyper8 or CL-1 or XB8 TQ ttr_racer R/C Items: Wanted to Buy 0 05-22-2006 08:48 PM
777 SP1 Vs. Hyper8 IronTusk Electric Off-Road 4 03-26-2006 04:24 PM
