Old 07-12-2006, 01:17 PM   #331
Motorman007's Avatar
Trader Rating: 78 (100%+)
Originally Posted by motomanpat
I just checked out the (specs)hehehe and they state 4 port but maybe I shouldn`t belive everything I read.
I know where you seen the 4 port thing.
Towerhobbies. hahaha
yeah they are wrong. hahah
not the first time.
YOU WILL (ALWAYSWIN).....
Motorman007 is offline   Reply With Quote
Old 07-12-2006, 01:37 PM   #332
motomanpat's Avatar
Actually it is also on the amainhobbies site but maybe I need glasses I am gettin kind of old at 35.Talk to you all later I gotta go to hell I mean work!Where did you get all those pro posts sir?
motomanpat is offline   Reply With Quote
Old 07-12-2006, 01:49 PM   #333
Rocket42's Avatar
yeah motoman i used to race motocross but not very seriously i won a 125 beginner class race in 97' i was 16. i still ride i currently have a crf450x its a blast i raced it once but just for fun i was the only one in my class 25+beginner i take it to the track every now and then for fun, i just bought a cbr600rr so now i can ride almost everyday for work. good luck with that engine it will be fast.
see i told you what happened had you bought a more expensive buggy you would have when cheaper on the gear but since you got the hyper 8 you will have all top of the line equipment that will last you the next 5-8 years (not including engine of course but servo's and radio) let me tell you this it is much much more fun to drive a car with top of the line electronics.
Rocket42 is offline   Reply With Quote
Old 07-12-2006, 02:30 PM   #334
KB has it wrong on his site too..
Old 07-12-2006, 03:53 PM   #335
i need a good Base Start for my hyper 8, i run alot of tracks with straight aways, pretty big jumps, wide open.... and tight lanes... anybody help a brother out?? thanx...
Pinnacle003 is offline   Reply With Quote
Old 07-12-2006, 04:08 PM   #336
Rocket42's Avatar
hey pinnacle check page 7 i posted what i think is a very good base setup for the car and it has worked for others in this thread with some changes.
Old 07-12-2006, 06:49 PM   #337
KK-racing's Avatar
Originally Posted by Rocket42
ok here is my base setup that i have worked into on the car it is a very stable aggressive setup and should work good for most drivers, or most drivers shouldn't have to make too many changes to suit there style. please remember that i'am always testing and my next thing will be to drill out the third hole in the front arm. so this is my current setup.
front:
3,000 diff oil
inside hole on arm second hole out from inside on tower.
1.4mm pistons 40wt. oil stock blue springs. 10mm pre load
6 degree kick up
20 degree caster block.
middle ackerman hole.
upper camber link location.
0 degree toe in/out
0mm sway bar pre load
center:
3,000 wt. diff oil
jammin crt fiberglass brake rotors.
rear:
2,000 wt. diff oil
inside hole on arm third hole out from inside on tower
1.4mm pistons 30wt. shock oil stock blue springs 2mm pre load
3 degree anti squat
306mm (narrow) rear track width
drilled rear camber link
3 degree rear toe in
2mm sway bar pre load.
middle wheelbase
if you like more steering use the rear ackerman hole if you would like less steering use the middle hole on the front shock tower.
i dial out lot of droop but i also like the rear end to have more droop than the front by about 2mm. (i'am refering to tightening the droop screws as dialing out and more droop by loosining the droop screw) if you are traction rolling at all with this setup tighten those droop screws. or if the car feels unstable tighten those droop screws.
i would also like to hear what some of you guys think of this setup. so if you try it out i'am sure you won't be dissapointed but i would like to know what you think. if there is anything i forgot let me know.
Hi Rocket42
I think I would like to give your set-up a shot this coming Sunday race. The only difference I would make is using the lower camber link hole for the front suggested by you in your later post, as I am not getting enough turning traction plus power on pushing even with new CF(M2 with molded medium insert) tire.
By the way, what are the following mentioned in your set-up & what are their purposes ?.
1) Front 6 deg. kick up
2) Rear 3 deg. anti squat
3) 306mm (narrow) rear track width
Do 'IT', with a DUREX (safely) !!!
KK-racing is offline   Reply With Quote
Old 07-12-2006, 07:30 PM   #338
tex1's Avatar
Send a message via Yahoo to tex1
Talking KK.....
Front kickup refers to the flatness of the lower front hinge pins. The flatter thay are the more side bite your front end will have when you slow down. The more kick up = better rough surface traction and on power forward bite.
This also adds to your castor value.
Anti squat = flattness of the lower rear pins. The principle is the same in the rear as it is the front. Flatter is better on smooth tracks and gives side bite when slowing. Antisquat (or kicking the forward section of the pin upwards) is better for rough surfaces and forward traction when you speed up.
Narrow track width is more responsive and wider track width is more stable. He is opting to run the narrow track width in the rear.
Hope this helps,
TEX
Hey Dibbs - you need to come to Dallas one Friday night and run at SRH with us.
We need some more Hypers to help me beat up on all of these Xray guys.
www.indyrcworld.net
Indy RC World 2.0 - Garland, TX
T&T RC Cars - Plano, TX
(972) 271-4844
tex1 is offline   Reply With Quote
Old 07-12-2006, 08:02 PM   #339
Rocket42's Avatar
kk-racing i think you will like the setup you should just run it the way it is posted first and if its a tight track just change to the rear hole on the ackerman (steering plate) for more steering.
i have been running this setup for awhile and for me it is enough steering more steering than my jammin. but if it is not enough steering you will know exactly what to do to improve it.
when i get to the track next (may be a couple of weeks) i am going to test drilling the third hole in the front arm and changing the front camber link and see which setup works best.
Old 07-12-2006, 08:18 PM   #340
its a 3port. just sometimes they count the exhaust port as an extra port. six of one, half dozen of ....
Berkky is offline   Reply With Quote
Old 07-12-2006, 08:48 PM   #341
Moderator
WYLDTHING's Avatar
Trader Rating: 148 (99%+)
Well, here she is....Got it back together tonight, finally....
Ready to see how it's gonna do this weekend when the competetion will be stepped up several notches. Should be fun no matter what!!! Anyway....
Ofna Hyper8 stingray-h81.jpg   Ofna Hyper8 stingray-h82.jpg   Ofna Hyper8 stingray-h83.jpg   Ofna Hyper8 stingray-h84.jpg
<>< JESUS IS MY HERO! ><>
==TEAM NOVELTY==
WYLDTHING is offline   Reply With Quote
Old 07-12-2006, 10:39 PM   #342
Rocket42's Avatar
purple wing looks sweet! good luck this weekend.
Old 07-12-2006, 11:29 PM   #343
KK-racing's Avatar
Thanks tex1 for the clear explanation & Rocket2 for the advice.
Maybe tex1 would want to drop by here & help me kick some of those X1CR guys asses. Over here the X1CRs dominate the scene, as well as the podium finish most of the time. We have only about 2 ~3 Hyper8s including mine & a mixture of XB8, MP777, MBX5, Lightning-Pro & Storm CL-1.
Old 07-13-2006, 12:25 AM   #344
motomanpat's Avatar
Hey WYLDTHING seeing those pictures is making me excited.Mine is on the way should only be a matter of days before I get my hands on it.Good luck to you this weekend!!!!
Old 07-13-2006, 06:02 AM   #345
here is a vid of a hyper 8 working out
http://www.18special.com/news_130706.htm
Video Battle Practice Lap
Hyper8/8.5 Dietz R/C Items: For Sale/Trade 13 12-31-2007 09:04 PM
hyper8/8.5 parts Dietz R/C Items: For Sale/Trade 1 10-23-2007 07:26 PM
hyper8 pro dwillard R/C Items: For Sale/Trade 2 08-03-2007 01:47 PM
WTB!!! Hyper8 or CL-1 or XB8 TQ ttr_racer R/C Items: Wanted to Buy 0 05-22-2006 08:48 PM
777 SP1 Vs. Hyper8 IronTusk Electric Off-Road 4 03-26-2006 04:24 PM
