Old 05-15-2006, 08:20 AM   #136
Panther's Avatar
Send a message via AIM to Panther
Originally Posted by asw7576
Big bore shock = more oil ?
From which car ?
I was thinking to buy GTR shock from REVO.
Yes, the Jammin Big Bores.......
-Seann
Panther is offline   Reply With Quote
Old 05-15-2006, 10:30 AM   #137
Rocket42's Avatar
if your running the jammin shocks why use the mugen springs why not the red jammin springs. i've always found the mugen springs to be more springy than others
Rocket42 is offline   Reply With Quote
Old 05-15-2006, 11:08 AM   #138
Panther's Avatar
Mostly because I've seen that Bradley and alot of those guys runs those at times and I wanted to give them a shot and see how they fair. They have treated me fair and I can say that I have noticed that they do have a bit of bouncyness too them. It's not a day and night difference, but it does make the car feel a little more on edge as compared to the Hyper 8 stock blue springs.
Just like with any other form of racing, if you don't try new things you're never going to get faster........So why not give them a shot?
I have the Jammin Red ones as well. I'm going to run the red ones this weekend and see how those do.
-Seann
Old 05-15-2006, 10:31 PM   #139
asw7576's Avatar
What do you recommend for bumpy track ? 450F - 350R silicone oil enough ?
I'm using the stock white piston disc .... and don't want to drill the piston disc.
LHS owner said to drill them to 1.4mm or 1.5mm and use thicker oil for viscosity consistency during final, 600F - 450R .
Old 05-16-2006, 12:18 AM   #140
asw7576's Avatar
Anybody sell one piece Hyper8 engine mounting ?
I hope someone make 2mm lower engine mounting so the starter box can grip the flywheel better.
Old 05-16-2006, 04:39 AM   #141
Panther's Avatar
I had the same issue with my flywheel, so I now use the Jammin Flywheel on my engines. They are larger. As far as the one piece mount......I don't feel that they are necessary. I had the Jammin one on my X1-CR and I didn't care for it a whole lot because you couldn't access the back plate on the engine before removing the mount.
From what everyone said, drilling of the rotors makes the stock shocks smooth out much better. I never did run them that much before switching to Big Bores. I generally run anywhere from 20-30 weight in the rear and 45-60 in the front depending on how big the track is.
-Seann
Old 05-16-2006, 06:05 AM   #142
anybody know what j-concepts bodys fit the hyper 8?
flysti is offline   Reply With Quote
Old 05-16-2006, 08:11 AM   #143
asw7576's Avatar
Is it low profile ?
Hyper8 body is low profile. I guess better aerodynamics.
Old 05-16-2006, 08:14 AM   #144
asw7576's Avatar
-Seann
Thanks ..... so Jammin flywheel should do allright.
I would like to try Mugen Seiki MRX4 engine mount and MBX5 flywheel. Hope it works too.
Old 05-16-2006, 08:15 AM   #145
Panther's Avatar
That's what I use on my WS7IIx3 and my S5 and it works great.
-Seann
Old 05-16-2006, 08:20 AM   #146
asw7576's Avatar
Anybody care about camber for Hyper8 ? What do you offroad guys normally use for front and rear camber ?
Old 05-16-2006, 04:44 PM   #147
Rocket42's Avatar
-2 degrees camber is a pretty good starting point for both front and rear camber.
asw drilling the pistons to 1.4mm or a number 54 american drill bit will make the car slighlty more aggressive around the track i recommend running 1.4 pistons all around with 40 to 35wt. in front and in 30 to 25wt. in the rear. i would start with 40-30 thats what i run and i think it handles great.
panther i don't know what you mean by drilling the rotors to smooth out the shocks, but i have been running the stock shocks for awhile and have had no problems with them they are very smooth. but if you want crazy smooth add some associated green slime, my stockers are like butter.
as for a jconcepts bodies go all i can say is write jason at jconcepts.net and ask what they recommend they are very good about helping there customers and responding right away to emails.
Old 05-16-2006, 04:58 PM   #148
Panther's Avatar
Just had a momentary lapse of stupidity.......I meant the pistons.....not sure why I put rotors??
-Seann
Old 05-16-2006, 07:16 PM   #149
I am running a kyosho fly wheel with kyosho carbon clutch shoes with 1.0 springs, I also drilled the pistons with a #54 bit, for the front shocks I am running 50 weight oil with kyosho sp2 dark blue springs, in the rear I am running 32.5 weight oil with kyosho light blue springs. The shock oil is Trinity
No more sponsors just doing it for fun and to see the look on a newbs face the first time they put their car on the track and hear their name called over the PA system
Howard C. is offline   Reply With Quote
Old 05-16-2006, 11:54 PM   #150
kjuliussen's Avatar
What springs and oil should i use with jammin big bore shocks on Hyper 8?
kjuliussen is offline   Reply With Quote
Hyper8/8.5 Dietz R/C Items: For Sale/Trade 13 12-31-2007 09:04 PM
hyper8/8.5 parts Dietz R/C Items: For Sale/Trade 1 10-23-2007 07:26 PM
hyper8 pro dwillard R/C Items: For Sale/Trade 2 08-03-2007 01:47 PM
WTB!!! Hyper8 or CL-1 or XB8 TQ ttr_racer R/C Items: Wanted to Buy 0 05-22-2006 08:48 PM
777 SP1 Vs. Hyper8 IronTusk Electric Off-Road 4 03-26-2006 04:24 PM
