Old 09-04-2014, 01:41 PM   #16
TruggyDude91's Avatar
Originally Posted by pdmustgt View Post
So because he does it it's better? If there tighten correctly you won't have issue
I offered this as an alternative idea to his situation. I didn't say it was better. If a collet is junk, it doesn't matter how much you tighten them down.
TLR - O.S. Engine's - Bone's Brew - JConcepts - Airtronics - Protek R/C - Diggity Paints
8IGHT 4.0 - B2101 W/2090, Protek 170s, RX472
8IGHT-T 4.0 - XZB VER. III W/2090, Protek 170s, RX472
TruggyDude91 is offline   Reply With Quote
Old 09-04-2014, 01:45 PM   #17
Originally Posted by token View Post
I believe Ty uses a standard 3 shoe clutch. The one for the TLR 8 3.0 is different.
I don't think it matters how many shoe clutch they use. The collet should be the same no matter how many shoes are on the flywheel. But I could be wrong... I think most flywheels utilize the same taper on the collet.
Old 09-04-2014, 01:54 PM   #18
Per my understanding, the orginal post was about a collet on TLR 8 3.0. The clutch on a TLR car is different. The flywheel, the shoes, the way the shoes mount and the tools used are different. The collet is a bit shorter than a regular 3 shoe clutch...
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 09-04-2014, 04:54 PM   #19
You're way off course. He's using Losi clutch parts then you jump ship with what Ty uses. Then somehow went to tighten nut down won't matter if collet was junk. I talking about issue was mostly caused by it NOT being tighten
pdmustgt is offline   Reply With Quote
Old 09-04-2014, 05:16 PM   #20
merdith6's Avatar
Default yeah
That's even worse. I would throw the losi clutch in the trash and use a Mugen setup. Much better and more standard parts.
Mad Dog drives a Mugen MBX-7, Novarossi engines, Clockwork Racing, Futaba radio, AKA/Proline Tires
merdith6 is offline   Reply With Quote
Old 09-04-2014, 07:11 PM   #21
madweazl's Avatar
Surely you arent stating that the Mugen setup is more common than the Losi? There are at least 10 to every 1 Mugen out there and probably more like 20+.
RadioPost
Mugen MBX7r | CRE Picco 5TR/2120 | Hitec 7950/7940
Tekno NB48 | B6 Pro/2058 | Hitec 7950/7940
Kyosho RB6 | Viper VTX10r/Reedy Mach 3 9.5 | Hitec 7940
Schumacher SX3 Pro | Viper VTX10r/Reedy Mach 2 8.5 | Hitec 7940
madweazl is offline   Reply With Quote
Old 09-05-2014, 01:03 PM   #22
Isnt it the same standard 3 shoe clutch system all the other cars use?
Old 09-05-2014, 03:16 PM   #23
merdith6's Avatar
Default no
The losi clutch is very specific. it has a really small brass collet and it is not standard. It is a 4 shoe design too. Most 3 show clutches copied Mugen on their design. So it's standard across different brands with similar designs and the collet is steel and lasts forever with no issues.
oops I kind of misread your post. you are right mugen is more standard.
