Old 08-25-2014, 12:08 PM   #16
What Im told from a very good engine guy..... The lower the fuel gets in the tank, the warmer the engine will run. This should only be a few degrees in temp. I cant definitely tell when my fuel gets low.
Make sure your pressure line is not bent to much restricting the air that goes in to the tank.
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 08-26-2014, 05:41 AM   #17
Trader Rating: 18 (100%+)
I only place heat shield tape on the inside of the body to protect from heat and also I cover the whole side of the tank that is near the pipe which help in consistency in fuel temps.
TLR 8ight 3.0, ''Houstonized'' P5XLT
TLR 8ight-E 3.0, Tekin RX8 gen2, T8 gen2 1900
Savox Servos
AKA Tires
Byron's Fuel
donbeatya is offline   Reply With Quote
