Starter Box: 4S Lipo + Tamiya connector ok?
#16
Tamiya connectors do work but they won't be as reliable.
#17
you guys are high. mine is hooked up via tamiya connectors and it's fine. but I use 2 2s lipos. (truggy ofna box)
it doesn't even start to struggle turning over any nitro i've started with it so far. (1/8 scale buggies)
ignore the electrical tape. I soldered the wire together before I stuck the heat shrink on. it's fine. ugly but fine. besides, your car you drive to work is full of electrical tape.
#18
see all those other connectors in there? you think they're any better? if you're going to worry about the battery connectors it's a must to replace the rest. or all you did was waste good connectors on the battery connections.
it's only as good as the weakest link. and I see plenty of weak links miles worse than the tamiya connectors.
you're also not using the box continuously like it's a car. if your engines aren't starting that easy to where you are running the starter so long to heat up the connectors, you've got bigger issues than a starter box connectors. take it to someone that knows how to tune the engine for you. you're band aiding other problems. that's my 2 cents.
#20
Take a look ard at the tracks. There is a reason why we don't put Tamiya plugs on starter boxes but u can do what you want.
I re-wired my starter box FYI.
#21
#22
http://www.hobbyking.com/hobbyking/store/RC_PRODUCT_SEARCH.asp?strSearch=ec5
