Air bubbles.
Air bubbles.
My son just bought a brand new cen matrix fte cheap as by the way. After finishing putting it together it was time to run it and a brand new motor in ( an mit b5 blue edition) Running it in using heat cycle method. During the first tank I noticed a lot of air bubbles going thru the fuel line which in turn made idle go up and down and in turn made the engine keep stalling ( Its a tight engine but ive run in a lot of alpha engines with great success)
Whats the problem never encountered it before.
R/C Tech Elite Member
This is almost always a leak in the tank. The small piece of fuel tubing between
the nipple and filter/clunk. Does the problem go away with a full tank? If it goes
away when you have a full tank its internal. If not then there may be a leak at
the fuel nipple or line.
