gas engines to take over nitro in 1/8?
#46
Bad for health has not so much to do with gas or nitro, its the oil a 2 stroke burns.
Someone should make a rotary engine for RC cars, far beter power/size ratio compared to piston engines.
#47
You mean still is...http://www.youtube.com/watch?v=jowo58yldpE
Man i must have watched the original terrafirma henry segment one million times!
#48
Nitro
How is the impact of nitro RC on the environment measured? The energy density of nitro over gasoline is known. For applications like RC and top fuel drag racing gasoline just won't ever be able to get the job done. For an RC application, weight and size of the equipment and the fuel tank are important. The existing set up is already filling out the chassis. Besides. I like the way cars were made when you could open the hood and fix them yourself. That is what I love about nitro RC. I can build it. I can fix it. And how well I do that affects how well I drive it! It is a simple as ice cream and I would like to see it stay that way.
#49
Amen!
#50
Gas is the way to go. 2 strokes can still stay. It will do to fuel racing what lipo did to electric racing, even if you don't believe it. Previously working at a couple hobby shops, the main thing that turned people away from nitro was the cost of the fuel. Now you can get cheap fuel and run for longer times. Exactly what lipo's did for electric, they were cheaper and provided more run time.
#51
#52
If we want cheap fuel, we just need to push the development of engines that run on FAI fuel. Even the high dollar 0% stuff is only 12 bucks a gallon.
I have a .28 that I am going to convert to run 0. If I can make the same power as a .21 and get the same run times, it's going in my buggy.
Methanol and castor oil are cheap... cheap as gas. No electronic ignition to mess with.... Seems like a better short term solution to me, if you are worried about the cost of nitro.
#54
That's for 4 gallons.
Methanol is 3-4 bucks a gallon. Could mix your own 0% for way cheap. Just add the Klotz or castor. Just like running a gas two stroke.
#56
- EFI and electronic ignition has been on RC airplanes for 10+ years. It's not a big deal. The EFI is just a throttle body EFI. No complex or super fancy $$$ tuning is required.
-displacement is a non-issue. We've run .28's in buggies for a while. Noone really cares. Run what ever engine you want. Let the pieces fall where they will. As long as the rest of the car is ROAR legal, it's not a big deal.
-the ignition is tiny. Making sure it's 8.4v lipo friendly is the key. Most airplane ignitions are not lipo ready.
-responsible use of refueling IS the key to gas racing. Refueling is often banned in 1/5th scale racing due to safety concerns. Nitro doesn't burst into flames and injure everyone on pit lane the way gas can.
-it's only a matter of time until the weight comes down. But Ebuggies are 0.5-1 pounds heavier than my nitro.......they get around the track well enough. (the Kyosho MP9 is 2 Oprah's, and a bag of lead, heavier than an Xray, and it fares ok.)
-who says you can't add Nitro to your gasoline and retune compression and ignition timing??? Might need a little TAG body spray to start reliably?
#57
You guys are thinking about this wrong. I really doubt that the 2 stroke gas engines will ever take over the nitro but give it time (and race organizers to allow it) and I see them both being able to compete in the same class on the same level. Are Nitro engines bad to breathe the exhaust? Heck yea but is breathing a gas engines exhaust any better? Maybe fractionally yes but still. They both create exhaust fumes so that's not really an issue. The gas engine in the Losi seems slow because its in a huge, heavy monster truck. Imagine the same engine, with proper gearing, in a 1/8 buggy or truggy.
#58
gas engines now available
Dynamite DYNE0500
http://www.horizonhobby.com/products...gsReviews=true
http://www.advantagehobby.com/253172/DYNE0500/?pcat=390
many shops are selling it in Germany also
http://www.mhm-modellbau.de/part-DYNE0500.php
http://www.hobbydirekt.de/Horizon/Mo...0::273552.html
Dynamite DYNE0500
#59
Only Yamaha has four stroke sleds all my ski doos are 800cc 2 stroke twins and I ride a new yamaha yz 250 its a 2 stroke. I am sure 2 strokes will become a thing of the past soon. The power to weight ratio of a 2 stroke is hard to beat. Something that is really cool about my ski doos you push a button for reverse and the motor runs backwards no gears.
Anyway, id love to see gas engines make it to 1/8 scale buggies. $3 a gallon instead of $40. Easier tuning. Easier starting. Less heat. Wicked 2 stroke smell. Cheaper parts. But not nearly the revs
#60
Lot of broken conrods among the XXL-2 guys... Something definitely seems flawed.
