Using 4 Glow plugs in two hours??? gg :eek: >
Old 01-24-2014, 01:17 AM
Default Using 4 Glow plugs in two hours??? gg :eek:
Hey guys just got my friends nitro car going and the motor (gx21 kyosho) is using lots of glow plugs :/ the motor was just rebuilt at the hobby shop with a new piston and sleeve. The tune is good but yet it just goes through glow plugs like crazy, any ideas?
henrybrooks321 is offline
Old 01-24-2014, 02:08 AM
Roelof's Avatar
Wrong headshims?
Roelof is offline
Old 01-24-2014, 02:13 AM
malcnz's Avatar
Originally Posted by Roelof
Wrong headshims?
yeah or wrong plug?
malcnz is offline
Old 01-24-2014, 02:50 AM
dan_vector's Avatar
Trader Rating: 27 (100%+)
Or bad rear bearing?? Conrod wear can also cause the engine to eat glow plugs. I'd tell him to stop running the engine, strip it an inspect for wear. Continued use is not a good idea!
dan_vector is offline
Old 01-24-2014, 04:04 AM
aussies1129's Avatar
Trader Rating: 74 (100%+)
Possible head button clearance?
aussies1129 is offline
Old 01-24-2014, 04:49 AM
Motorman007's Avatar
Trader Rating: 89 (100%+)
I say buy a new motor...
If you have the cash.
Like the others say it could be
head shims
wrong plug
bad rear bearing
Conrod wear
Which will cost you more vs buying new sir.
Something to think about.
Motorman007 is offline
Old 01-24-2014, 06:23 PM
hotrod87's Avatar
Trader Rating: 252 (100%+)
Are you sure it's not to lean ? That's the most common reason to burn them out.
hotrod87 is offline
Old 01-24-2014, 06:48 PM
packerbacker's Avatar
Sounds like classic bearing case.
packerbacker is offline
Old 01-24-2014, 08:17 PM
OK thanks guys must be a bearing since the motor was not running lean
Old 01-24-2014, 10:25 PM
houston's Avatar
Trader Rating: 96 (100%+)
I vote somebody didnt put all the head shims back and u r using too hot of a glow plug
houston is offline
