HELP DNX408T
HELP DNX408T
I have a problem with handling. I am fairly new to rc racing and I have recently bought a new dnx408t and had 2 race meets. my problem is everytime I give it a good amount of throttle it pulls to one side. it can go to the left or right. it makes it impossible to line up big jumps as I cant hit them going straight. also on the main straights it is just pulling to one side as soon I give it full acceleration forcing me to back off instantly. I have tried changing a few things but have had no luck at all
Yea that sounds like some bearings on the Rear hubs or diffs . Check them.
Or your steering trim is off on your radio .
its definitely not steering trim as will stay in a straight line until I give it a good amount of throttle. when it is only under say a quarter throttle it will stay straight but as soon as I give it say 3/4 throttle or more it hooks to either side
cheers I will do that
Sounds like some bad bearings somewhere in the drivetrain also i know from a long time ago i heard that it could cause your truck or buggy pull to one side when on the throttle .
yes it can go either way lol. and everything in the truggy was brand new ... just finished building it. out of curiosity could it be because im running a hobbyking 20kg servo worth $20
If you can easily move the wheels, then either the servo is too weak or your servo saver tension is set too loose.
I'd guess it's either diffs or something in the steering.
I will try it and ty to everyone for taking your time to help out. I appreciate it guys
