Help
Help
i have to remove the engine mount screws from my buggy but they won't move, they are too tight what should I do??
you can use a hair dryer, that or put the driver in then use a hammer and tap on the end as you try to turn them. Have you tried the screws underneath or just on the engine from the top? You can use a hammer on either set the same as a blow dryer if you can't get a heat gun
Or you can use a soldering iron. !!! Just hold it on the bolt for a while then give it a tap with a hammer as said previously.
Cheers guys. The first two were easy. The other two required a blowtorch, a hammer and a Allen key . And the last one required a dremel, a blowtorch and a flathead screwdriver
You can torch a screw and not get the engine any hotter than it's normal operating temps.
You just want it hot enough to heat the threads, then as it cools there will be a point where it will let go/come loose.
If you use heat and parafin wax melted into the threads (if you can get to them from the top side) it helps. the Parafin will "run" into the threads when they're hot. Acts as a lube. Usually found in grocery store w/canning supplies. Chap stick can also work.
Yea I only wave the blowtorch over for a few seconds till its warm.
