Old 03-17-2013, 06:45 PM   #1
MotoGod's Avatar
Trader Rating: 112 (100%+)
Send a message via AIM to MotoGod Send a message via Yahoo to MotoGod
Default Grub screw stripped inside axle stub....
Anyone got any ideas on how to get the darn thing out? I tried a few drill bits, but the grub seems to be hardened steel or something. Since it's inside the axle stub....I can't get my screw extractor in there either. I'm about to just hack off the hex and or the axle stub. lol
Scott Pouliot
Current Race Rigs: TLR 8ight 3.0/3.0E/3.0T/22/22-4
Thanks to my 2015 Sponsors: LutzRC, RadioPost, AKA Tires, RC Addition Products, Nitro Pro Fuels
MotoGod is offline   Reply With Quote
Old 03-17-2013, 07:38 PM   #2
Trader Rating: 75 (100%+)
I broke a 1.5mm of in a grub screw and been trying to get that out.. Dang grub screws...
gixxer420 is offline   Reply With Quote
Old 03-17-2013, 07:53 PM   #3
Trader Rating: 38 (100%+)
Always use a left handed drill bit. They will usually catch whatever you are drilling and back it out.
John Barr
On-Road: VBC WildFireD08; VBC Lightning10; VBC Lightning12; VBC Lightning10-235mm
Off-Road: Not likely
Special thanks to EMRFactory and VBC Racing.
linkless is offline   Reply With Quote
Old 03-17-2013, 08:46 PM   #4
nitrosevers's Avatar
Trader Rating: 21 (100%+)
if a left handed drill bit or a true screw extractor wont work you need to buy a special bit for drilling hardened steel cobalt bits should work just fine for anything in an rc car just drill slow and if you have any cutting fluid use it, if cobalt wont work a solid carbide bit will cut almost anything.
This space is available for sponsorships!
nitrosevers is offline   Reply With Quote
Old 03-17-2013, 09:02 PM   #5
I haven't found screw extractor that will bite into hardened steel ends up ruining extractor. Ones I've had tried from major tool guys end up junk unless someone has found ones that do work
pdmustgt is offline   Reply With Quote
Old 03-18-2013, 04:00 PM   #6
where do you buy left handed bits ive checked my local hardware store which is an Ace
#1)Team Associated RC8.2 / #2)Mugen Seiki mbx6r / #3)Kyosho Mp9 Tki3 / Savox / Spektrum / LRP / Rwmodded Argus A52/ Alpha A872 / Werks B5x2 B5 prox1 / Sponsors My Wife and Mastercard
I might be slow but I'm in front of you.
dooug1960 is offline   Reply With Quote
Old 03-18-2013, 04:03 PM   #7
sschultz's Avatar
Trader Rating: 15 (100%+)
There used to be an industrial supply store by the grf airport that carried them. Otherwise, talk to somebody at ace, they can probably order...
Shane Schultz
sschultz is offline   Reply With Quote
Old 03-18-2013, 04:06 PM   #8
Jaz240's Avatar
Trader Rating: 52 (100%+)
drill it out with the diamond bit for a dremel Scott. You'll probably need a new hex but save everything else
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 03-18-2013, 04:06 PM   #9
Triumph twist bit makes one that will work with hardened steel, and its made in USA
Old 03-18-2013, 04:09 PM   #10
I can get them here locally if you tell me what size I can send you one.
Old 03-18-2013, 07:58 PM   #11
I had to get one of these out of a mid shaft on a losi on the weekend.
Cutting a slot with a fine cutoff wheel (to use a blade screwdriver) and then heating with a mini-torch didn't work. Tried cutting down one layer and slotting again with heat and no dice. Tried one more time going down another layer and still no dice. In the end we had to grind out the screw and its housing right down to the nub. That little bastard held on until it was .5mm thick and hot as hell from grinding - then it gave up the ghost.
But try heating it with a mini torch first. Its a must-have tool in my kit. You might just free it up.
Proudly sponsored by:
Pinnacle Hobbies
GLORCS RESULTS:2006: Buggy 20th, Truggy 12th 2007: Buggy 44th 2008: Buggy 10th 2009: Buggy 8th 2010: Buggy 10th, E-Buggy 2nd 2011: Buggy 9th, E-Buggy 7th
Gump is offline   Reply With Quote
Old 03-19-2013, 12:51 AM   #12
Flat Head screw driver, sounds pretty rough but works a treat, find a cheap shitty one that is slightly larger than the hex and smack it in with a hammer or the likes, it will cut its own groove and bed in when you twist it, have removed many a stripped screw with this method when I haven't been able to notch it with a dremel, I've found screw extractors don't work the best just make a mess of it and then you're poked, give the crew driver a shot, theres not much to loose with it really.
B.C.Ninja is offline   Reply With Quote
Old 03-19-2013, 04:26 AM   #13
Stubbs's Avatar
Trader Rating: 57 (100%+)
I've had this problem a couple times in the past. What works for me (if heat, and a LH drill bitt won't get it out), is to simply take a pin punch, and drive the cross pin out using a hammer.
Unless there is a flat on the pin, the grub screw won't be able to hold it, and it will come out without much fuss. This will allow you to get the hex off without damage, and will also take the load off of the grub screw.
I've been able to back them out afterwards with a little heat, and a small flat head screwdriver jammed in the stripped hex.
Of course Scott, if you took the hexes off to change bearings more than once every presidential election, it would likely not get stuck in there!
Just messin' with ya bud....if you don't have any pin punches, I'll bring mine, and we can get it out when we get down to PNB.
Mike Stubblefield - www.capefearraceway.com
"If you're not racing to have fun, then you're doing it WRONG."
"All you need is WD-40 and Duct Tape. If it moves, and it shouldn't, use the Duct Tape. If it doesn't move, and it should, use the WD-40."
Stubbs is offline   Reply With Quote
Old 03-19-2013, 05:21 AM   #14
killerkustoms's Avatar
Trader Rating: 16 (100%+)
I bought a set at Harbor Freight and possibly Northern Tools might have some.
VP-PRO USA/ST-RR EVO/PowerMaster 30%/Futaba 4pk/Argus R8
killerkustoms is offline   Reply With Quote
Old 03-19-2013, 06:28 AM   #15
MotoGod's Avatar
Thanks for the advice guys (except for you Stubby, you get to sleep on the roof of the RV at PNB now!). I'll see what I can use to get this sucker out. Good thing I don't NEED it to come out right now....my D812 is on a UPS truck headed to my house sometime today so I get to build the new kit for PNB now ;-)
Scott Pouliot
