Old 03-19-2013, 07:38 AM   #16
BillyT.'s Avatar
Originally Posted by B.C.Ninja View Post
Flat Head screw driver, sounds pretty rough but works a treat, find a cheap shitty one that is slightly larger than the hex and smack it in with a hammer or the likes, it will cut its own groove and bed in when you twist it, have removed many a stripped screw with this method when I haven't been able to notch it with a dremel, I've found screw extractors don't work the best just make a mess of it and then you're poked, give the crew driver a shot, theres not much to loose with it really.
Or even better is to get a torx it that is slightly bigger than the allen and hammer it in. I do this all the time to get stripped allen heads out. Its like hammering 3 flat blade screw drivers in at once, quite a bit more grip on the screw.
Nemo Racing USA
Agama : Bullitt : Beta
[email protected]
BillyT. is offline   Reply With Quote
Old 03-19-2013, 07:42 AM   #17
MotoGod's Avatar
Trader Rating: 112 (100%+)
Send a message via AIM to MotoGod Send a message via Yahoo to MotoGod
Not a bad idea....I've got a bunch of torx in the trailer.....and a BFH, so I'll try this when I get home. Not sure why I didn't think of the flat blade or Torx approach. Normally I dremel a slot in a stripped screw and yank it out that way....or use an extractor. hehe
Scott Pouliot
Current Race Rigs: TLR 8ight 3.0/3.0E/3.0T/22/22-4
Thanks to my 2015 Sponsors: LutzRC, RadioPost, AKA Tires, RC Addition Products, Nitro Pro Fuels
MotoGod is offline   Reply With Quote
Old 03-19-2013, 02:43 PM   #18
BillyT.'s Avatar
It doesn't take much hammer power... you can tap it in with the end of a screw driver.
Nemo Racing USA
[email protected]
Old 03-19-2013, 11:37 PM   #19
Bahahahahaha RC Hobo's to the rescue, love the torx idea, kinda in reverse to what I normally do, i never have torx so use a hex to get them out hahahaha.
B.C.Ninja is offline   Reply With Quote
