Team Associated RC8B3 Nitro Team Kit
#3241
Just got done building my RC8B3. Built it per the instructions for set up. Now I have it on my Hudy Set-Up Station and the chamber is not equal on both sides. I double checked the pin inserts and all the shimming to make sure they were the same on each side. They are. The one side shows .75* of chamber while the other side shows 2.25* (should be 2.5*). Is there something I may have done wrong or missed, or is it common to have to have different shims on each side? Thanks for any insight.
#3242
PSM makes some nice easy to insert Pillowball suspension shims without taking the whole thing apart and I am waiting for AMain to stock them to get some.
http://www.psm-shop.com/option-parts...-0.7-/-0.8mm-6
http://www.psm-shop.com/option-parts...-1.2-/-1.4mm-6
#3245
Pretty sure the RC8B3 is going to be the main 1/8 platform until 2018.
#3248
The internal diff shimming on the RC8B3 is different than the kits in the past. The supplement included with the kit can only explain so much, so here are the tips I've put together with input from Richard Saxton and Kody Numedahl:
1) When building the diffs new and checking the shimming, build them without any fluid. This will be the best way to "feel" the diff action. Basically you want the diffs as tight of shimming as possible without any crunchy feeling. Some drag is okay, but definitely not notchy.
2) Start with the shimming as tight as possible. This is achieved by having two shims behind each planet gear, two shims behind each sun gear and no paper gasket. If the diff action is notchy, you'll need to "loosen" the mesh some.
3) The first way to loosen the mesh is to add the paper gasket. If the action is now smooth, stop here. If not, proceed to step 4.
4) If the diff action is still notch, remove the paper gasket along with one shim behind the sun gear on the ring/spur gear.
5) If the action is still rough, add the paper gasket back in.
This is as loose as we've found you'll have to run the shimming. Each diff is slightly different, so make sure you take your time with this part.
NOTE: The the screws should be VERY TIGHT in to the pumpkin. Most don't tighten them enough and this allows the internal gear mesh to vary. Richard suggests using ti screws here to get the best bite.
#3249
It makes it less aggressive.
#3250
Can some give ,me the matching clutchbells for 46spur besides the stock
#3251
Reds Clutch
Question for those that run the reds quattro clutch..
Which flywheel size did you get?
Reds says to get the 32mm one, kinda strange..
#3252
im designing a Front skid plate wing for the MBX7R does anyone have the measurments for the hole pattern for the front..just need the OC in mm...with and length..i have everything else
