Team Associated RC8B3 Nitro Team Kit
#1741
This isn't a motorcycle that's using gyroscopic force to manipulate its balance not to mention one wheel completely off the ground with the machines CG being almost vertical. And the reason the rear tire is rotating in that situation is because its on a hinge since the CG is vertical. Has absolutely nothing to do with braking. That was a very poor analogy. In order to make a 4 wheel vehicle "rotate" around corners you want more rear brake than front brake especially at high speeds with sweeping turns. More front brake creates understeer via front biased weight transfer which opposes the cars ability to "rotate".
#1744
Got to say that I love this buggy! Its great even on a loose sandy/clay track like I run on. Ran Tanners Day setup and hubs forward with Proline X4 Suppressors. Money.
If your on that fence cause peeps say this or that. Get one! Or not. Love beating the other 30 TLR's. At least I try right! haa
#1748
Email AE and see what they do
#1749
Bent both ends on first outing with that car. Found out after I saw that I lost the play I had on the front arms. You probably won't notice it on the first bend, but as time goes, metal fatigue will snap it. Would've been nicer if it had a little more meat around the mounting holes. M2C makes a beefier one, and AE is working on a replacement also.
#1751
I built all my diffs as instructed in the manual/addendum and checked the mesh to make sure it was correct. 5 of the diffs were built according to those spec and 1 diff I had to remove one of the shims behind the big gear to get the mesh right. I'm not sure why some guys aren't using gaskets. The local team guys i've talked to are...my diffs seem good, no issues or leaks yet.
#1752
My nitro kit came with an addendum to the manual and the necessary shims for it, my e buggy's manual was updated so no addendum was needed, again it included all shim necessary.
#1754
had same this issue, i did change with kyosho and the ball as well. but theres a bit gap with the pin and arm. then i put some bit shim before i place the pin to the ball. theres any suggestion for make it fit properly without puting some shim ?
#1755
42T Diff ring gears on their way.. Part #81004
There will be also 46T..
Lets see when these will be available heh
