Question for Nitro guys in the Midwest
#46
#47
When things cool off in the fall and early spring we race here! Works excellent! Not a lot of heat in the cold but we get use to it. I just wish it worked out to hold a winter series here again! It's located near Motley Minnesota.
http://www.rctech.net/forum/8799358-post1.html
#48
#49
Motodome was one of the places that also ran indoor dirt bikes. Looks like a pretty sweet place.
#50
I will try to get name off the system. Basiclly it's long sheet tube 3x3 roughly 30 foot long with with inlet and outlet fans on one end pointing away from each other. Using same plastic flexable tubing we use on the track hooked to inlet fan running through sheet metal tube then to hard plastic tubing that run near the floor to differnet point around the shop. Outlet fan pulls air through sheet metal tube over and around flexable plastic tubes thats where the heat transfer happens. It does work surprise it does we had doubts when they were installing it
#51
http://www.keeptheheat.com/ this is the name of the system we use at work... I'm sure there are others who builds something like this
