Like Tree2Likes
Old 07-29-2013, 03:08 PM   #1261
golferdude1971's Avatar
Trader Rating: 18 (100%+)
Originally Posted by cornerspeed View Post
4x8mm flanged
Thanks.
golferdude1971 is offline   Reply With Quote
Old 07-29-2013, 06:57 PM   #1262
Trader Rating: 120 (100%+)
I know everybody has their preference on suspension springs and what not but I am here to tell you that the stock kit springs work great and and from what I saw this weekend and many other weekends by the awesome driving display that the Weatherholt boys and Tyler Jones put on at the MSCS Race that this buggy doesn't need anything else or and other brand springs. Just change the stock rear springs to green and your golden. Thank you to Mike and Randy for all the setup help. It was much appreciated.
22-4
MBX7R Eco, RC8B3E
MBX7R. RC8B3
JoeC is offline   Reply With Quote
Old 07-29-2013, 09:44 PM   #1263
Trader Rating: 21 (100%+)
Hey guys i am looking at some different options and thinking of switching brands and trying the 3.0. I am wondering what parts or hop ups are needed on this car out of the box?
EastTxRacer is offline   Reply With Quote
Old 07-29-2013, 10:03 PM   #1264
Drill the extra camber link holes in the rear shock tower. Set it up and go racing!
Gsnow39 is offline   Reply With Quote
Old 07-29-2013, 11:56 PM   #1265
shanef's Avatar
Trader Rating: 38 (100%+)
Another little mod which is a good idea to do, is to put a bearing in the throttle swivel arm thingo. Drake explains it here - http://www.youtube.com/watch?v=Fp8gIEm8BbQ
Instead of using the LOSA6912 bearing which is $20, use the LOSB1728 bearing which is only $5 for the pack (use a 5mm drill bit). You'll need to use a 2x12mm cap head screw and M2 lock nut instead of the kit screw (make sure u use the washer as well). When you tighten up the nut, be careful not to over tighten it as it will bind. No more slop and the screw will never back out either.
Part numbers:
LOSB1728 - 2x5x2.5mm bearing
VTR235006 - 2x12mm cap head screw
VTR236012 - M2 lock nut
Pic below of how it looks.
shanef is offline   Reply With Quote
Old 07-30-2013, 07:29 AM   #1266
Is anyone aware of an "uncut" body for the 8ight 3.0?
Ben Burtle is offline   Reply With Quote
Old 07-30-2013, 08:24 AM   #1267
KingdomRacer's Avatar
Part numbers:
Another choice for a bearing for the mod for us here in the U.S. is get it from Avid for a $1 and it's flanged which is what you really want for this mod.
http://www.avidrc.com/product/1/bear...-bearings.html
JESUS says, "Fix it B4 it Breaks, 'cuz a DNF is a SIN".
Alpha-RC.com/RcRenew.com/TritonRC.com
VPProUSA.com/UpGrade-RC.com/KalGard.com
Green-Gorilla.com
KingdomRacer is offline   Reply With Quote
Old 07-30-2013, 08:42 AM   #1268
BMenard17's Avatar
Trader Rating: 88 (99%+)
Any other brand that fits the 2.0 will fit the 3.0 as well... Hope this helps.
Tekno R/C-Sweep racing tires-Rc addiction products
Lead finger racing-Hobbico-OS engines-Futaba-Odonnell
BMenard17 is offline   Reply With Quote
Old 07-30-2013, 09:32 AM   #1269
trx450racer174's Avatar
Car is great out of the box. Only thing i added was aluminum top plate and aluminum servo saver arm.
And I also drilled the rear lower camber link hole.
E.K.D. RC Paint Work
Team Serpent USA, Desoto Racing , Team DE Racing, Team Hitec, Team Trakpower, Futaba, Team AKA, TrackstarRC.
trx450racer174 is offline   Reply With Quote
Old 07-30-2013, 02:35 PM   #1270
Do you know anybody who has the green rear springs in stock? A Main says there out til mid October.
old carpet rcr is offline   Reply With Quote
Old 07-30-2013, 04:27 PM   #1271
EBAY and Nitrohouse.com has some. tlr243020
dynamiteracer is offline   Reply With Quote
Old 07-30-2013, 04:41 PM   #1272
Thank you, just ordered them.
Old 07-31-2013, 05:31 AM   #1273
Trader Rating: 52 (100%+)
Part numbers:
does that work on the brake side also?
Mo Denton-www.mnkraceway.com
Team Losi
Proline,-Redrock Hobbies-,VP Powermaster fuel,Darkside Designs,Speedy Bills!
fast for an old guy
Mo Denton is offline   Reply With Quote
Old 07-31-2013, 05:53 AM   #1274
Mr. Jones will know. I knew I should of asked him first.
22-4
MBX7R Eco, RC8B3E
MBX7R. RC8B3
Old 07-31-2013, 07:03 AM   #1275
Trader Rating: 19 (100%+)
We having bearing mod on brake and throttle.
Randy
RandyJones is offline   Reply With Quote
