Old 06-01-2013, 03:47 PM   #721
Trader Rating: 16 (100%+)
Originally Posted by Tarimon View Post
Whats the "Zero Hole"? An additional inner hole for the camber link?
Where did you get info on that...?
Many questions...
Thanks for answering...
To be honest the guys at my lhs that are die hard Losi fans gave me this mod. I searched high and low but didn't find any info on it. But when I ran my AE car that was the must do mod to lower the roll center more if I'm not mistaken. I haven't tried my Losi with this mod due to bad weather but I'm all over it tomorrow.
Larry Bromell
Mugen/AKA/MKS/Orion/Flashpoint
jaron_cc is offline   Reply With Quote
Old 06-01-2013, 04:24 PM   #722
Originally Posted by Team_Elli View Post
Where do you guy's mount your transponder? because i couldn't find a mounting location for it...
Imagine a full size spektrum receiver a full size transponder and the two miles of hitec servo wire all tucked nicely away inside the smallest box Losi could find FML!
Larry Bromell
Old 06-01-2013, 04:38 PM   #723
Tarimon's Avatar
Hmm, okay...
But, if you lower the inner camber link, you will raise the roll Center on the rear of the car...
...my Transponder Location...
--- Mugen MBX-7R-Eco - Viper VTX-8 - Hacker 1900 - DX4-R Pro - Hitec 7945TH ---
--------- Asso B44.3 - Team Orion R10.1Pro - GM Pro D9T - Savöx 1252MG --------
---------------- If you canīt race or f*ck it, it ainīt worth having ----------------
Tarimon is offline   Reply With Quote
Old 06-01-2013, 04:51 PM   #724
cornerspeed's Avatar
If you run that lower hole on the rear tower, it is suggested to run the lower inside front camber link location on front tower also. That is the exact location where I drilled my rear tower. It is the same as 2.0 middle hole.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 06-01-2013, 06:06 PM   #725
Correct, but like I said I only did it cuz of the guys that run Losi, this is my first Losi kit ever minus trying a 22B. When I ran it a few weeks ago the car felt fine just very loose in the back I Lengthen my rear camber link and moved my hubs forward and it calmed down a bunch.
Larry Bromell
Old 06-01-2013, 06:50 PM   #726
This is a great mod and may even give you too much bite dependant on the track and surface. The back end will be a lot more predictable and I am sure you will love it. I did.
flap jack is offline   Reply With Quote
Old 06-01-2013, 10:09 PM   #727
Vinny Cancilla's Avatar
I was told by a someone that this mod frees up the rear, not lock it in. Lowering the camber link raises the roll center.
Serpent Srx8
Serpent America: Triton engines/ Nitro pro.Fuel/ Rc Addiction products : Vp pro Usa/Dialed-Rc
Barnstormers: Chester, NY, N.Y.. IRH Lindenhurst
Vinny Cancilla is offline   Reply With Quote
Old 06-01-2013, 10:49 PM   #728
True, if the track has high bite, then raising the roll center will keep the car from rolling too much, keeping it from being twitchy or screwing itself into the ground. I ran into that last weekend at a race. The track was watered for the first round, but not for second round. The track dried up really fast and turned high bite blue groove. So I lowered both camber links on tower and that kept the car flat and really driveable for the conditions.
Donny Vinkemulder
TLR Driver
Old 06-02-2013, 12:38 AM   #729
PAGIE #536's Avatar
anyone tried different spring rates on the front ?
-Simon Page-
AKA Australia/Ryper Hobbies
https://www.flickr.com/photos/simonpagephotography/
www.facebook.com/SimonPagePhotography
PAGIE #536 is offline   Reply With Quote
Old 06-02-2013, 01:11 AM   #730
juzza99's Avatar
Simon, are you using anyone's particular setup?
juzza99 is offline   Reply With Quote
Old 06-02-2013, 04:17 AM   #731
LOL are you sure that's not a spypicture of my recover box? Cause it looks just the same.:-D
*Sanwa M12*Hitec*
*TLR Eight 3.0*Fusion X3LFM*
Team_Elli is offline   Reply With Quote
Old 06-02-2013, 05:03 AM   #732
PAGIE #536's Avatar
Post
not as of yet mate, only ran the car twice so far, so running the kit setup minus the shock oils, dropped the rear too 325cst which is equivalent to 25wt and 500 cst in front which is around 35wt still feels stiff in the front, I don't think the spring is the correct rate for the piston combo/oil on the front well not to my liking anyway.
-Simon Page-
Old 06-02-2013, 05:07 AM   #733
juzza99's Avatar
Ok, cheers.
I'm going to start with drake std setup with green rear springs and also overdrive on front end.
Old 06-02-2013, 01:51 PM   #734
Tarimon's Avatar
Questions??
But, what I did not get:
The 3.o has the LowerRollCenter-HingePinHolder in the kit to lower the rollcenter, and then we drill an additional hole in the Tower for the camberlink to raise it again...???
Someone able to explain..?
Old 06-02-2013, 02:45 PM   #735
The explanation is that one setup will not work for every driver and every track.
Matthew Bailey is offline   Reply With Quote
