BUMP BOX SHOWCASE-show us your setups
#61
heater
for you guy that are running you comp heater of your box are you running them right of the battery or a switch. i have mine coming right of the battery but if it wrong will switch it but i use an arm safe dean plug for mine and i can also charge it thought this plug. This is a dry cell also no lipo here yet.
#62
remember to wire them up after the on/off switch or they will drain the battery
#63
i actually ordered the ones from hobbyking metioned in the thread earlier and used them on this box , i like them better as they have a short plug that can be moved to different pins to create 2s-8s monitors , dialed!
you will be fine , just be careful you dont kill your comp heat unit with that gel cell
