Hot Bodies D812
#1246
#1247
#1251
Does anyone know if these servos will work with life or lipos?
Im thinking of using this one for throttle
http://www.amainhobbies.com/product_...ium-Gear-Servo
And this one for steering
Or should i go with the pro tek 150's..?
#1252
All done!! well I decided to try mechanical brakes so we will see if it will drive like the nitro. Also need a extension wire for the servo, longer motor wires and the ofna servo horn to match the front.
Rear of the chassis notch at the very end and removal of droop ear.
Front needs very little, may have to remove some of the droop ear but I chose to leave it because if I cut it off at all there will be no place or way to put the droop screw on the chassis so Im happy the way it is for now.
Remove the keys one to the right is gone working on left in the pic.
#1254
#1256
#1257
#1258
