Old 08-03-2013, 06:35 PM   #2746
Trader Rating: 68 (100%+)
I have these new in the package.
Front arms $15
Bulkhead $5
Steel skid plate $3
Universal rebuild 2 per bag $4
2) Bags shock bladders with O-rings $4 each
1 bag of shock/swaybar link pins. 3 in the bag $4
Like to sell all in a lot $35 free ship inside the country.
Dealer for Serpent, Intech, Agama, Pro Speed, JQ Products, Tekno
Alpha,Triton, Picco, Reds, Go, Arrow,Bullitt,Beta
Sponsor- Nemo Racing.
Greg B is offline   Reply With Quote
Old 08-03-2013, 07:09 PM   #2747
Trader Rating: 53 (100%+)
Send a message via AIM to nv529
Originally Posted by Brandonmorris44 View Post
Iv made the changes that y'all recommended to me on my 812 and it calmed the car down a ton . I'm running 5-5-2 with 37.5 front oil 35 rear with around half rebound and white spring suspension feel good in the car as far as jumping landing and cornering but it seems like its very easy to roll it over if not careful . Over a bump or maybe a sharp corner is this from to stiff of suspension ? Possibly the tires ? Roll center need to be moved closer to cg ? I was running on a blue groove high traction indoor track with bar codes maybe it was a traction bite causing the roll not sure
Can you please post a complete set up sheet?
Nick Vasquez
Tekin | Reilly Paint | Dirt Burner Racing | RC Clubhouse| Washtenaw RC Raceway | TARCAR | The Track
nv529 is offline   Reply With Quote
Old 08-03-2013, 08:30 PM   #2748
Brandonmorris44's Avatar
Trader Rating: 33 (100%+)
Front arms $15
Bulkhead $5
Steel skid plate $3
Good deal here
Brandonmorris44 is offline   Reply With Quote
Old 08-04-2013, 12:37 AM   #2749
Yes I'll fill one out in detail and get it posted ASAP thanks nick
Old 08-04-2013, 03:50 PM   #2750
nacho_gas's Avatar
Is on sale type 6?
I saw it in the setup of Tessmann
Nacho Carrillo
I am Spanish. Sorry for my bad English
HB D812 / Novarossi Bonito & 4BTT / Futaba 4PK / Savox /
nacho_gas is offline   Reply With Quote
Old 08-05-2013, 11:06 AM   #2751
Trader Rating: 50 (100%+)
Default Did use D8T hex wheels
I experienced as well how the D812 oversteers. I did some tweaks on the buggy by using D8T hex wheels on the rear of the D812 to add rear track-width to increase rear grip at corner entry as well as high-speed on-throttle steering. Here are some other changes I've made:
FRONT:
shock oil: 40 losi
Rebound: 25%
upper shock tower: #3
lower shock tower: #2
Suspension arm shock position: #2
Sway Bar: 2.2 mm
REAR:
shock oil: 27.5 losi
Rebound: 25%
upper shock tower: #2
lower shock tower: #1
Sway Bar: 2.5 mm
DIFF OILS (used Mugen brand):
F: 5000 C: 3000 R: 2000
The rest of the set ups are on Ty's set up sheet on Dirt Nitro.
Since then, I was able to run the D812 harder than before.
I ran this setup at revelation raceway last Saturday for Summer series with great result
R/C is my stress reliever...
R/C makes me happy...
R/C is my dream but I'm not the only one...
R/C is irreplaceable...
R/C for life!!!
twt_07 is offline   Reply With Quote
Old 08-05-2013, 04:23 PM   #2752
nacho_gas's Avatar
Are these the hex?
http://www.amainhobbies.com/product_...el-Hub-Black-2
Nacho Carrillo
Old 08-05-2013, 04:31 PM   #2753
nacho_gas's Avatar
You can see a video of my car.
+ YouTube Video
Nacho Carrillo
Old 08-05-2013, 07:31 PM   #2754
+ YouTube Video
Your track doesn't have many jumps I would suggest using 1.3x8 pistons with 30wt rear and 40wt front, it should calm the car down which seems to be bouncing around a lot.
Nick Vasquez
Old 08-05-2013, 07:37 PM   #2755
Has anyone used the new Jconcepts body yet?
http://blog.jconcepts.net/2013/06/jc...ies-d812-body/
Nick Vasquez
Old 08-05-2013, 08:11 PM   #2756
Trader Rating: 31 (100%+)
Originally Posted by adubaz7 View Post
Hey guys I am looking to use the shocks off of the D812 for my buggy as they are correct lengths for my setup, my question is are the shocks the same as the hara buggy just different length bodies and shafts? Reason I ask if they are the same is I had a hara buggy and loved the shocks but I need the lengths that the D812 are. Can anyone let me know?
Can anyone tell me if the d812 and hara are the same shocks just different sizes or are they different in some other way?
Andy Watts, Gilbert Arizona. I would like to thank:
Tekno RC, Castle Creations,
Rw-Mods and Argus Engines
MKS Servos, Protek RC, Amainhobbies
Kenny Brosh, Fear Farm RC Track
adubaz7 is offline   Reply With Quote
Old 08-05-2013, 08:22 PM   #2757
D812 shocks are much longer 106mm front and 124mm rear vs D8 hara's 98mm and 112mm
Nick Vasquez
Old 08-05-2013, 08:31 PM   #2758
I am aware of the lengths that is why I posted that the length of the D812 shocks is what I am in need of but want to know if there are other differences I don't know about like taller caps or different bladders or seals or internal bore sizes. I never asked what lengths they were you answered my question the first time the same way but I don't think either time you actually read the question. I don't have a Hara as stated I used to have one and thought the shocks were the best I have worked with but the hara shocks are not long enough for my current buggy and the D812 shocks are the right length I just want to make sure the shocks are the same with the exception of the body lengths and shaft lengths. Please someone who has built both the hara shocks and D812 shocks can you confirm that the shocks are the same with exception of body and shaft lengths?
Old 08-05-2013, 08:36 PM   #2759
nice track! the conditions are very loose, slippery and bumpy. does it clean up on a race day and give better traction?
by the way... i would use alot more air filter oil than what you currently are, especially with those loose and dusty conditions. you should be oiling both parts of your filter liberally. dust particles are smaller than the holes in your air filter and dust will kill your engine very quickly!
+ YouTube Video
picko990 is offline   Reply With Quote
Old 08-05-2013, 08:39 PM   #2760
interesting obversation nick. i would agree except i would have thought it was unavoidable since the track is so bumpy. are you saying it is possible to smooth that out some more? can you please explain a bit more what you are thinking?
thanks
jason
New Hot Bodies Buggy!!??????? monsteraddict Nitro Off-Road 14489 03-18-2013 01:42 PM
