Old 11-09-2012, 09:55 PM   #1
rcking112's Avatar
Trader Rating: 25 (96%+)
Default Ackermen question On the Losi 8T 2.0
http://www.amainhobbies.com/product_...g-Ackerman-Set
Would choosing the short Ackerman Increase steering?
I have read in the JQ " The Guide" That A Short ackerman "plate" will increase steering
Is This true?
Thanks.... for the help
Looking to increase the steering alittle on my truggy without changing much, and its a small and quick change if i dont like it.
and if i do change it.. what would be the Adverse effects? Lose rear traction? things like that?
Team Serpent , Proline , 92 Zero Designs , CowRC Factory Team
Srx8
Srx8E
Srx2MH
rcking112 is offline   Reply With Quote
Old 11-10-2012, 06:34 AM   #2
Losimoe's Avatar
Trader Rating: 18 (100%+)
a quote from the losi manual
"A long Ackerman plate will have smooth off-power steering and is more forgiving. The long Ackerman plate will have more steering on-power. A short Ackerman plate responds quicker and has more steering in the middle of the turn. A short Ackerman plate is better suited for tight technical tracks." -losi manual page 36.
give the manual a good read mate. its got a lot of info on setups. you can download it directly through their website.
Losi 8T 2.0 Novarossi HS7950/40
Losi 8E 2.0 MMM ---> needs a conversion kit
FASSSST!
All you E guys need to get rid of that "Nitro Patch" on your arm.
Losimoe is offline   Reply With Quote
Old 11-10-2012, 04:15 PM   #3
rcking112's Avatar
So Basically the shorter plate will give me better steering for my Tight Technical track?
I run indoor nitro at the factory and its really tight... ill give that a try.. thanks!
Srx8
Srx8E
Srx2MH
