Old 11-08-2012, 07:20 PM   #1
nazUK's Avatar
Default Starter Box Belt keeps spinning off
Hi
I tried looking for a thread of someone who may of had the same problem but could not find anything.
So as the title says my starter box belt keeps coming off the wheel, what's the best solution for this?, is it cause the belt is loose?
I must add at this stage that the belt is a pretty tight fit.
Anyway suggestion are most welcomed
nazUK is offline   Reply With Quote
Old 11-08-2012, 07:51 PM   #2
nitroexpress's Avatar
It might be easier to help if you listed the brand and model of the box. Different brands may use different methods to tension the belt. Pictures are always helpful.
nitroexpress is offline   Reply With Quote
Old 11-08-2012, 07:57 PM   #3
nazUK's Avatar
OK I didn't think it would make a difference but anyway it's a kyosho multi starter box pro 2.0.
No pics at the moment will put some up later
Old 11-08-2012, 07:59 PM   #4
nazUK's Avatar
Theres a pic of it here
Starter Box concern with LIPO Battery - Need advice?
Old 11-08-2012, 08:28 PM   #5
Did you change the position of the motors in the box? I would suppose that the different possible motor postions would require the belt tension to be set. Seems pretty straight forward. Page/box #3 shows the belt tension adjustment.
Old 11-09-2012, 04:19 AM   #6
nazUK's Avatar
OK but are you saying it should be looser which will stop the belt coming off?!
Old 11-09-2012, 08:08 AM   #7
No.
You did say that the belt was quite tight, so I don't know what to tell you.
Old 11-09-2012, 08:24 AM   #8
afr0sch's Avatar
Trader Rating: 95 (100%+)
Send a message via MSN to afr0sch
Um....read the manual?
"Life is tough, but its even tougher when you are stupid." - John Wayne
afr0sch is offline   Reply With Quote
Old 11-10-2012, 04:18 AM   #9
nazUK's Avatar
No.
Well then your answer to my question doesn't seem to be an answer at all, adjusting the motors is one thing but if it doesn't correct the problem where the belt is slipping of then I'm back to square one.
But I will try it and see what happens, but what I will say is the belt has become slightly looser by adjusting the motor.
I have one question that has come to mind...
How loose should the belt be/how much slack should it have?
Old 11-10-2012, 08:12 AM   #10
bigjayjay1's Avatar
Trader Rating: 86 (99%+)
If you look at the two drive motors and there screws if the belt is super tight then I would slack some tension off buy pushing the motor. Also make sure the Pully idler spins freely if it's not you will have issues. Play with the belt tension if you have a friend with a box feel his and compair
TEAM: SERPENT AMERICA DRIVER -ADVANTAGE RACING PRODUCTS-COMPETITION HEAT INC - HOBBYPRO, VPPRO - BCE-
Serpent: 811N, 811T, 811E
bigjayjay1 is offline   Reply With Quote
Old 11-10-2012, 09:51 AM   #11
Are you by any chance breaking in a new engine with this box?
Old 11-10-2012, 02:28 PM   #12
nazUK's Avatar
Thanks bigjayjay that's really helpful advice.
I have a feeling now it may be too tight hence why it is spinning off.
Old 11-10-2012, 02:30 PM   #13
nazUK's Avatar
No nitro my engine kicks in fine but I think bigjayjay may of, as they say,
"hit the nail on the head"
Old 11-10-2012, 02:44 PM   #14
One thing to check. Do you have the idler pulley (adjusts tension) in the correct position for the motor position chosen? Page/box #3
http://www.kyosho.com/jpn/support/in...df/36209_m.pdf
Old 11-10-2012, 03:04 PM   #15
nazUK's Avatar
I did but the belt became too too tight so I loosened it, just didn't feel right the belt being that tight, but now I have adjusted motor I may try it again.
