Cleaning
Cleaning
I have a 1/8 scale ofna buggy. Years ago when I used to have my tmaxx I used to take it through the mud and everything else and would actually disassemble it to clean it. Now I do not have the time I used to when I was a kid to do all that. What have you found is the easiest way to clean your cars. I have some all purpose cleaner or denaturated alcohol. Just spray it down real good and then use a air compressor to dry everything off and wipe it down.
What do you guys do?
I pull the engine and radio tray. Wipe those down by hand. Simple green and rinse the rest of the buggy with water. Air compressor to dry then apply prep and shine/pledge or whatever you prefer to detail. I like my cars looking new after every race day. Takes me about 20 minutes each tops.
I am the same way man. I have an old ofna ultra mbx that I have had for years and I just put a new .28 on it but it looks brand new. I will post a picture here shortly.
Here is a picture
I used to spray my buggy down with simple green and spray it down until I pulled my diff out one day and it had rust on it...I blew it off with the air compressor and use a heat gun to dry it...Now i'm tearing it down and cleaning it takes longer tho
I don't recall a little rust ever hurting anything on a nitrobuggy.
I used to rinse mine down after pulling engine and tray. But that washes dirt into the bearings and CVD's.
Now I brush the car off, hose it down with Silicone Lube spray (dryer than WD40). Coat that with TAG body spray and then brush and wipe some more.
Yeah the rust was not much but got me worried. Silicone lube spray? Where can I get that
I get most major dirt off with paint brushes then remove the engine, radio tray and clean those. If I want my car to be spotless, I disassemble it all, rebuild diffs and shocks, take apart and clean engine, and apply Trakpower detailer with a clean paint brush. I use paint brushes and paper towels to get every spec of dirt off of it, of course, I don't do this often because its a lot of work if the next morning I'm just gonna run it on the track again, in that case, I just wipe with paint brushes without disassembling anything.
Simple green diluted 10:1
I remove the radio tray, tank and center diff from the bottom and the motor from the top, brush or blow off all loose dirt, put a little wd 40 on all bearings and then wash and towel dry. Then, I use my own proprietary formula, Truggy Love, and everything looks awesome. Brush it on and wipe off any excess. Or, just brush it on very sparingly. It is not for sale but I am giving away samples if anyone wants to try it send me a pm. So far everyone that has used it has given a positive response.
